Does a 2016 Prius Four have the a lithium hybrid battery?
Discussion in 'Gen 4 Prius Technical Discussion' started by Banksy, Feb 10, 2021.
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    I read somewhere that some of the 2016s had the older style batteries in them
    I’m interested in a 2016 Prius for with 85k on it and want to know if it’s a newer style battery that’s in it
    Also is 12k a good deal on that car if it’s in very good condition?
  2. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    You are asking about a Prius 4 (I assume you meant "four" rather than "for"), correct? It has a Lithium Ion main battery, as do all the other trims except the Prius 2.
    Banksy likes this.
  3. Banksy
    415
    132
    Yes, I am talking about a four
    all the twos have the older style ones?
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Raytheeagle, Banksy and davecook89t like this.
  5. davecook89t
    1,092
    826
    Yes, I believe the Prius 1 had the NiMH battery as well as the Prius 2, if you should happen to come across one of them. I understand the Prius 1 was only sold to local governments.
  6. jdenenberg
    jdenenberg EE Professor
    3,954
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The AWD-e (mine is a 2020) has the older NiMh battery pack. My 2016 Prius 3 had the Lithium Ion battery pack.
    JeffD
    Pulse07 and davecook89t like this.
  7. davecook89t
    1,092
    826
    Right, I could have mentioned that, but I don't believe a 2020 model will be within his price range.
  8. Elektroingenieur
    2,515
    3,287
    Three Touring
    I’ve posted a cross-reference to grades (trim levels), VIN prefixes (WMI/VDS), model codes, and HV battery types.
    davecook89t and SFO like this.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I wouldn't worry either way - it has little bearing. Both have the same tested MPG/l/100km. Most of the world got NiMH, only Japan and some models in America. We still get NiMH in Australia
    The only real advantage of Li-ION is that it's a bit lighter. It has slightly quicker charge/discharge patterns, but in a hybrid environment it makes little effect. And NiMH has better performance in temperature extremes, particularly cold. And heat - can affect longevity.
    The biggest difference I can see is that NiMH has been around for much longer - thus proven in Long Life situations - with Gen2 TAXIs recorded as having run them for up to 800,000 kilometres (or that might have been miles??). There seems to be less degradation with NiMH during the lifetime - but only time will tell, as Gen 4s have only been around for 5 yrs now.
    davecook89t likes this.
  10. PtPri
    PtPri Junior Member
    91
    40
    Lisbon, Portugal
    Luxury
    My 2016 gen4, with NiMh batteries, and 88.529kms (55.009miles), just now:
  11. bisco
    52,421
    nice
    PtPri likes this.
  12. Mendel Leisk
    41,954
    The NIHM are rebuildable, and Lthium not so much, judging by John Kelley’s deep-dive video on a 4th gen battery pack. Believe it was a Prime battery, but same story, just more banks.
