Prius Prime Air Conditioning on Electric Power
Discussion in 'Prime Main Forum (2017-2022)' started by Lemon, Aug 16, 2021.
  1. Lemon
    Lemon New Member
    San Jose, California
    Hello!
    On a hot day, how long can I run the air conditioner on battery only before the engine has to come on? Assume Prius Prime (used model, say 2018) and starting off with 100% charge.
    Thanks!
  2. schja01
    schja01 One of very few in Chicagoland
    1,732
    1,157
    Chicagoland
    2018 Prius
    Lots of variables not the least of which is outside temp and humidity. You’re shooting at a moving target.
  3. m8547
    m8547 Senior Member
    927
    615
    Colorado
    2018 Prius Prime
    Maybe 2-6 hours depending on how hot it is.
  4. ForestBeekeeper
    ForestBeekeeper Active Member
    695
    269
    Maine
    My Prius will go 25 miles whether the A/C is on or off.
  5. ChapmanF
    15,111
    The Prime's battery capacity is quoted as 8.8 kilowatt hours.
    The air conditioning compressor is variable power, can be anywhere from over two kilowatts when running flat out, to under a tenth of that in mild conditions.
    Those compressor-power figures are what I've observed in my Gen 3. I don't expect Prime's to be a whole lot different, but I haven't looked the numbers up. Of course Prime's system is a heat pump and can also be used to warm the cabin in cold weather.
  6. bisco
    49,002
    so, depending on speed,that would average an hour?
  7. Lemon
    Lemon New Member
    Sorry I should clarify. I'm asking about a parked vehicle with the AC on. Ballpark range is fine. Thanksa
  8. m8547
    m8547 Senior Member
    927
    615
    Colorado
    2018 Prius Prime
    Usable capacity is actually about 6kWh. Just running the screens and gauges in the car and nothing else is at least 200W. On a mildly warm day with the AC on, the total power won't ever be below 600-800W, and if you're in the sun it will probably be more like 1.2-1.8kW. If you're somewhere unreasonably hot like Arizona it will surely be higher. So like I said, 2-6 hours.
    burrito likes this.
  9. Lemon
    Lemon New Member
    Awesome, that's exactly what I needed, thanks for the reply!
