2018 Prius Prime EV battery problem
Discussion in 'Prime Technical Discussion' started by Can Doan, Aug 15, 2021.
  1. Can Doan
    Can Doan Junior Member
    Boston, MA
    2018 Prius Prime
    HI all,
    Again, thanks all for great responding to my posting.
    Driving in the last 3 summer with AC was not a factor to my car, only in winter, when the temp down to teens, my car could drive up to 16 or 18.
    EdPalmer42, what is the OBD? And where I could borrow it from? Do they have it in the dealership?
    I talked to a technical manager of the dealer where I bought my car and the same place I have had maintenance for my car and the same place I brought my car for this problem 2 weeks ago. He asked me to give me sometimes so he could dig in this matter.
    Thank you all,
    Can Doan
    52,097
    nice of him to at least do some research, all the best!
  3. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Before you do anything, please take photos of the Eco Diary log which is shown in the photo below. From this MID display, if you push the center button on the wheel, you can scroll the dates up and down. Take photos of all 8 screens, (4 days/screen x8=32 days). This will show the changes in the daily miles/kWh for the last 32 days. It saves only the last 32 days, if you wait more days the oldest records get purged. I also attached the manual page that explains how to use the Eco Diary. These data will tell you if your daily miles/kWh is in good agreement with the EV range you have been getting.
    Can Doan and dig4dirt like this.
  4. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    OBDII (spoken as 'O-B-D two') stands for On Board Diagnostics - Version 2. It's a standardized port that allows anyone to talk to the various computers that are built into the car. AFAIK, all current cars and trucks from all manufacturers have this port. If you look under the dash just to the left of the steering column you'll find the standard OBDII socket. You can buy an OBD reader on Amazon, ebay, local auto parts stores, etc., but they can be expensive and likely won't give you the info you need. You can also buy an OBDII to Bluetooth adapter that allows you to run an app on your phone or computer and talk to the car that way. Price varies, but the cheap ones typically don't support all the necessary functions for newer cars. I use the OBDLink MX adapter, but it's been replaced by the MX+ adapter which is widely available for about US$100. There are other good adapters available, I just happened to pick that one.
    Dr. Prius is an app that's available for Android or IOS and provides various capabilities for car owners. AFAIK, it's the only app that shows the voltage of each of the 93 cells in the traction battery.
    Your dealer has something similar, but he won't loan it to you. He might give you the info, but he will probably charge you a service fee.
    If you search PriusChat, or use Google, you'll find lots of info on OBDII, Dr. Prius, and other apps.
    Can Doan likes this.
  5. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Dr Prius
    more info
    many people use it
    even if you do not know how to decipher, you can post screen shots or results here,
    and the great folks here can let you know what, if anything, it is showing.
  6. Can Doan
    Boston, MA
    2018 Prius Prime
    Which Bluetooth adapter could run best with Dr. Prius that I could buy on Amazon?
    Thanks,
    Can Doan
  7. Can Doan
    Boston, MA
    2018 Prius Prime
    Thanks and I will as soon as I could.
  8. Can Doan
    Boston, MA
    2018 Prius Prime
    I found this one on Amazon with great reviews and hope that could work well for me.
    Mestart OBDII OBD2 Bluetooth Car Diagnostic Scan Tool Auto OBD Scanner for Android Devices
    Thanks,
    Can Doan
  9. Salamander_King
    11,019
    8,954
    New England
    It should work, but there are some that are very cheaply made and not going to give the result you want. Read this blog article and decide if you want to take a chance or not.
    Hybrid battery diagnostic and repair tool for Toyota and Lexus
    It cost a bit more, but OBDLink LX (right ~$60) is extremely well built and very fast. If you want to go cheap, I suggest go with PanLong (left ~$12). Carista (middle ~$30) is another popular OBDII dongle for Prius owners, but I find it to be much slower than LX, and even slower than cheap PanLong.
    #29 Salamander_King, Aug 18, 2021
  10. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    I agree with Salamander. It's a bit of a crap shoot as far as adapters. I tried two cheap ones and neither worked properly on the Prime. One didn't have the necessary features and the other had the features but I don't think it was fast enough to keep up with the data coming from the car. The OBDLink MX seems to be doing the job. The LX should work, but Salamander's link says that there are problems with both the LX and MX. YMMV.
    Can Doan and Salamander_King like this.
  11. Salamander_King
    11,019
    8,954
    New England
    Yeah, I think it is app dependant too. Some apps work very well with a particular adaptor but not others. One good thing about the OBDLink adaptors is the company behind does a good job of updating the firmware. Others, no so great. I just tried using my OBDLink and PanLong on my 2021 PP with Dr.Prius app, both worked fine, no issue. On the other hand, I have been having problems using the new version of the Hybrid Assistant with my 2021PP. This seems to be the app problem, not the adaptor, but the Bluetooth connection gets disconnected. This happens with LX, Panlong, and Carista adaptors, and I have tried with three different Android phones, they all disconnect the adaptor as soon as the connect button is touched.
  12. Can Doan
    Boston, MA
    2018 Prius Prime
    I got the OBDII today and have a try and here what I got. Please what we can see from the attachment.
    Thanks,
    Can Doan
  13. bisco
    52,097
    it looks good. not sure about the 106% charge though
  14. Salamander_King
    11,019
    8,954
    New England
    I don't know much about how to interpret this App data. I will leave it to others more knowledgeable. At least, it does not look much different from what mine is showing. And mine is a brand new 2021 model with no deterioration.
    I think it is a bug in this app. At 0% SoC on the dash, Dr. Prius shows appropriate 14% SoC, but at a fully charged state, it always shows 105% SoC on mine. This number should be more like 80%. Any SoC in between 0-100% on the dash, the SoC number reading on Dr. Prius is completely linear.
  15. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    So far, so good. The 'voltage diff' is the difference between the highest and lowest cells. 0.01V is what you want to see. The 'state of charge' of 106.50% is a bit harder to interpret. Did you just charge the battery? The high SOC and the rather high temperature could be due to that. Using another app, Hybrid Assistant, I've seen that when the dash is displaying 0% SOC, Hybrid Assistant reports about 14% and when the dash says 100%, HA reports about 80 - 85%. This is just the car being really nice to the batteries and not charging or discharging them too much.
    Now you want to discharge the battery down very low - 0%, actually the Prime shows it as --% and take another screenshot. What you're looking for is an increase in the 'voltage diff' reading and seeing that one or more cells have a lower voltage than the others. Other posters have listed various things that could cause an abrupt drop in range. A few, maybe just one, battery cells that are getting weak will hold their voltage as long as possible, but they'll die quicker than the others and the car will react to the drop in the voltage of the pack by reducing the range.
    Also, if this test shows that there are no weak cells, then there's no problem with the battery - as far as we can see. The above mentioned 14% minimum SOC shouldn't be an issue because the car won't let you use that energy anyway.
    Ed
  16. Can Doan
    Boston, MA
    2018 Prius Prime
    Hi Ed,
    Thanks for reading and respond to this posting.
    As from the screen shot and the first time I monitored it during driving to work and I saw some blocks around #25 are always in lower if we compare to the others and at the time EV battery went out those area changed color to RED for couple seconds.
    I try to learn why my car after full charge it shows lower than used to. This morning showed 24.8 and driven only 20.1. Temp. out side was 72 and no AC was used. I did record the process, but honestly I don't know where it is yet.
    I will try to use the HA app tomorrow. I will take a screen shot when it runs out of battery later on the way home today.
    Can Doan
  17. bisco
    52,097
    have you checked to make sure the brakes aren't dragging?
  18. Can Doan
    Boston, MA
    2018 Prius Prime
    All brakes are brad new and serviced by pro. If so the mileage should be less but after full charge should not be changed, right?
    Thanks,
    Can Doan
  19. bisco
    52,097
    unfortunately, the display is simply a measure of battery percentage, converted into miles based on past driving.
    #39 bisco, Aug 24, 2021
  20. bisco
    52,097
    so if the car has a mechanical problem, or your driving route or weather has changed, tires and etc.
    thedisplay converts the same battery charge into less potential miles.
    we call it a guessometer, but if everything is consistent and working well, it is fairly accurate.
    #40 bisco, Aug 24, 2021
