2016 Prius will not start
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by gobiecki, Aug 16, 2021.
  1. gobiecki
    gobiecki New Member
    san diego
    Drove my car to carwash and back home, got in my car and it will not start, keyfob light works but doors dont unlock, no response on dash, 12v battery tested good, can't connect via obd port no response, what should i check, looked at fuses they all look good, door lock buttons work on doors, headlights, domelights work. radio center console has no power.
    51,884
    sounds like water infiltration, check all the fuses. what does '12v tested good' mean exactly
  3. gobiecki
    gobiecki New Member
    san diego
    Battery tested at 12.5Volts, all fuses tested good.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    Have you tried placing the fob next to the power button (the procedure to start when fob battery is dead)?
  5. Mendel Leisk
    41,389
    What sort of car wash, a pull-through car wash, stationary-and-the-equipment-moves car wash, or just a-bunch-of washers-swarm-the-car car wash?
    Was the interior "detailed" as well?
    If pull-through style car wash, did you have any warning on the dash, anything about low hybrid battery?
  6. gobiecki
    gobiecki New Member
    san diego
    It was a pull through car wash, interior was not detailed no warning lights, if i put key next to start button no dashboard lights come on.
