Missing intake manifold bolt
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by icyrius, Aug 22, 2021.
  1. icyrius
    icyrius Active Member
    238
    114
    Florida, USA
    2014 Prius v wagon
    Hello. Today while checking my son’s Prius engine fluids for a long trip, I noticed his intake manifold is missing one bolt. Not sure how this happened. My local hardware store did not have any metric bolt that could be matched.
    Do you know what is the right bolt that goes in here? I probably can order it online.
    Thank you for your help.
  2. JC91006
    JC91006 Senior Member
    16,796
    8,589
    You can probably get the bolt at any Toyota dealer for a couple bucks, that is the EGR Pipe in the picture.
  3. ChapmanF
    18,357
    At your Toyota dealer it is a 91551-80616, but it's also a bog-standard M6 if I recall correctly; no idea why the local hardware didn't have 200 of them.
  4. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    Home Depot has 'em: M6-1.0 10 or 12mm zinc plated flange bolt. Lowes probably does as well.
    xliderider likes this.
  5. PriusCamper
    PriusCamper Senior Member
    12,914
    5,240
    Pacific Northwest, USA
    yea, agreed... Got to a different hardware store.
  6. Mendel Leisk
    41,714
    #6 Mendel Leisk, Aug 22, 2021
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    What I would do?
    Get a generic bolt and swap it out for one in a non-critical location, like securing a harness bracket.
  8. ChapmanF
    18,357
    I would accept just about any odds that an M6 bolt from the local Tru-Value will keep that pipe elbow from falling off that manifold. :)
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,479
    2,459
    Taylors, SC
    The bolt is J.I.S. (Japan Industrial Standard) M6x1.0x16mm in length with a 10mm hes washer flange head. I have over 50 of them in my supply of spare parts.
    I've seen them in the drawers at Home Depot in ISO 8.8 grade, which is what Toyota uses for this application. 20mm length will work just fine, since they are through bolts.
    Mine are 10.9 grade which is higher, but not necessary.
    #9 Georgina Rudkus, Aug 22, 2021
    Mendel Leisk and JC91006 like this.
