Wheel alignment optimal values for prius 2017
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by AnasMuhsen, Aug 24, 2021.
  1. AnasMuhsen
    AnasMuhsen New Member
    Jordan
    Hello
    I have a problem with my 2017 prius 2 touring
    I need the optimal wheel alignment values; camber, caster and toe
    I feel that the car is sagging and not good in driving
    I went to 2 garages but each one gave me different values
    52,231
    do you have access to the service manual through techinfo.toyota.com?
  3. Mendel Leisk
    41,786
    Hopefully all the specs in this:
    zeng likes this.
  4. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    On freeway straight ahead driving with both hands safely and temporarily off the steering wheel for seconds, does the Prius:
    a ) travels straight like an arrow, stable and steady or,
    b ) the Prius drifts or veers towards one side of the lane slowly, say towards right hand side lane?
    Whilst driving straight ahead at freeway speeds, do you:
    c ) have to hold 'tight' to the steering wheel during driving for substantial duration, or
    d ) have no problem with both hands off the steering intermittently most of the time?
    Clarifying the above driving 'experience' currently as encountered by you, may provide guidance/context towards pointing out which one of either alignment print-outs above as being spot on or vice versa.
    #4 zeng, Aug 29, 2021
