Looking for an aftermarket lift kit installer in portland
Discussion in 'Prius v Accessories and Modifications' started by questionsabout, Feb 10, 2021.
  1. questionsabout
    questionsabout New Member
    wa
    2021 Prius PHV
    Does anyone have someone who could install a prius v offroad kit and maybe a hitch in the portland area?
  2. PriusOffroad
    PriusOffroad Active Member
    108
    167
    Chico, CA
    You could always make the drive down to Prius Offroad headquarters in Chico, CA. ;)
    hxs90 and Raytheeagle like this.
  3. PriusAdventurer
    PriusAdventurer Junior Member
    25
    Arizona
    Four Touring
    I installed the lift kit with a friend in about 3 hours. It's worth doing yourself if you have or know someone who has tools. You will need:
    1. Jack
    2. At least one jack stand
    3. 12-23 mm sockets and drivers
    4. A pretty powerful drill
    5. pry bar (can probably do without)
    6. Dead blow hammer
    I haven't done a hitch yet but from what I've seen it seems like a pretty straight forward install. The install will cost you more than the lift.
