Suggestions on shopping for a battery reconditioning charger
Discussion in 'Gen 2 Prius Technical Discussion' started by Sean2005Gen2CA, May 11, 2020.
  1. Sean2005Gen2CA
    45
    32
    Hi Prius Chat!
    Can you suggest where I can buy a battery "reconditioner" or charger for when I am "balancing" cells? I have seen the Prolong reconditioner, but it seemed a bit expensive at $350. Any more affordable options out there?
    Thank you!
    Juan Pablo likes this.
  2. Juan Pablo
    Juan Pablo New Member
    Missouri
    i buy HTRC cheap does the job. will take about a month with only one charger tho.
  3. vjekobalas
    vjekobalas Junior Member
    36
    Croatia
    There's quite a few hobby chargers mentioned in these forums but my problem is that whenever
    i try to find the manual for these mainly Chinese chargers, either I can't find the manual
    or I can't judge from what is written whether it does something or not.
    Was wondering whether someone could indicate whether their charger can
    - record the result of all the charge/discharge cycles
    - is charge/discharge info also available for reprocessing eg. if you want to combine
    data from several batteries on one graph ?
    - do multiple charge/discharge cycles according to manually defined parameters
    and the end of charge/discharge are sensed/ended properly
    - measure series resistance
    - maybe those with reconditioning experience could also mention if there are
    some other requirements that are essential to have
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    Your best course of action is to get:
    NONE.
    And save your money toward a new battery.
    Once the battery gets old enough that you recognize it is getting weak,
    "reconditioning" is just a a waste of time and money.
  5. vjekobalas
    36
    Croatia
    I would like nothing more than to do that or even better just buy a new car
    but my pocket doesn't allow it especially after
    this lab virus fiasco and the car is now sitting there, so practically I don't
    have another alternative.
  6. sam spade 2
    7,035
    2,800
    2017 Prius c
    What I am trying to tell you is that you DO have another alternative........since this one likely will end up being more expensive than doing NOTHING.
  7. dolj
    dolj Senior Member
    8,307
    4,245
    Wellington, New Zealand
    Too cryptic for me Sam, so what chance has someone for whom English is their second language.? Why do you feel you need to harass and bully people all the time? Give it a rest.
  8. dolj
    dolj Senior Member
    8,307
    4,245
    Some record info for multiple cycles, some only record the dayta for the last cycle.
    If you mean store to a CSV type file, no for the most part. You need to pay for asomething more expensive to get data logging.
    Most of the hobby chargers sor of do, but with some it is hard to get that working right.
    No, but you can theoretically calculate it.
    Are you looking at a battery that has P0A80 and/or P301x/P302x codes? Or do you have a battery with low voltage that you want to charge up?
  9. vjekobalas
    36
    Croatia
    Sam, I appreciate your input - it's always good to get feedback from more experienced people but
    a new battery costs about 2k Euro (I don't think the car is worth more than 10k Euro and it's already got
    180k km), a second hand battery 1k Euro(and who knows whether it is any better than this one)
    and I am hoping the OBD2 indication of the center module being weaker means a couple of modules
    need to be changed (100Euro) + chargers (250Euro) and a lot of my time (which we will not
    count as I now have more time than money). Like I said, if I had the money, I think I would just
    trade in the car for a new one or buy the new battery and drink juice on the beach but that's not my
    option now.
    This is for a 2013 Yaris Hybrid 178k km - this is the thread I started:
    2013 Yaris hybrid 1.5l 178k km P0A80 fault | PriusChat
    I used a VeePeak OBD2 adapter and found only the one code P0A80.
    I have the battery on the table and each module is disconnected but haven't had time
    to test it other than the open circuit test - I get 7.7V on all modules.
    As there are 20modules, I think I am looking at 4 or 5 chargers (or quad/ 2*2) whatever is best
    they can be with or without a power supply (have some pc supplies laying around) .
    I am in Europe and don't have access to all the chargers that are mentioned in the forum.
    Does the EV-peek CQ3 record multiple cycles and do the multiple charge/discharge cycles properly /
    is it a cheap charger that could be recommended ? Is there a better choice with or without power supply ?
    #9 vjekobalas, Sep 3, 2021
  10. sam spade 2
    7,035
    2,800
    2017 Prius c
    BUT you did not include any of that information in THIS thread.........so I assumed that your car was still running.
    So it is a slightly different situation.......but not much.
    You are still going to have to replace the cells that have failed completely......charger or no.
    Then other cells are likely to fail also in a few months.......charger or no.
    There is no "magic" in trying to recondition a battery.
    I wish you luck.
  11. vjekobalas
    36
    Croatia
  12. vjekobalas
    36
    Croatia
    I saw the CQ3 mentioned by experienced users in a few places and bought it for 146Euro delivered- couldn't
    pass up the opportunity. Thanks all for the input, now to reconditioning in my other thread.
  13. Seymour1
    Seymour1 Member
    249
    29
    I found EV Peak CQ3 chargers on AliExpress and GetFPV for $160 or $170. Too good to be true? A scam?
