Prius Coolant Thermos System
Discussion in 'Gen 2 Prius Main Forum' started by retepsnikrep, Nov 1, 2006.
  1. retepsnikrep
    retepsnikrep New Member
    Hi
    I'm a new UK member but I don't own a Prius at present. Can I ask the following couple of questions.
    Is the Prius Thermos Coolant heat saving feature standard on UK vehicles?
    If it is, does anyone know where in UK I can get one (The Thermos) from a crashed/salvage vehicle.
    If it's not a UK feature I might be willing to consider getting one from US/Canada or wherever they are a standard fitting. Can a kind US/Canada member help me with this?
    Thanks for your help. I have searched the forum and found some useful diagrams which describe the system, but I haven't found the answers to my specific questions.
    Some members might find my site interesting at www.solarvan.co.uk.
    Peter
  2. qbee42
    3,079
    I believe it is standard on all Prius, but I don't know that for sure.
  3. Tideland Prius
    16,618
    <div class='quotetop'>QUOTE(Peter Perkins @ Nov 1 2006, 12:49 AM) [snapback]341781[/snapback]</div>
    I thought the bladder and thermos were NA-specific. The bladder for sure, the thermos, I could be wrong.
    If you import, you'll have to change the lights as our lights will blind oncoming drivers on your side of the pond. Also, if you get HIDs (from the US), you'll need headlight washers so it's probably best not to get HIDs as it's not worth the hassle. Lastly, we don't have rear foglights.
  4. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :mellow: Just curious. Can't imagine why someone would want the "Thermos" only for a Prius. It's part of a system including a pump and interconnection with the ICE cooling system. It's difficult to see how it could be useful in a "non-Prius" application.
  5. sub3marathonman
    sub3marathonman Active Member
    557
    75
    <div class='quotetop'>QUOTE(Peter Perkins @ Nov 1 2006, 05:49 AM) [snapback]341781[/snapback]</div>
    He isn't kidding. That site and what he's done is spectacular.
    I too don't understand what you would need the Prius thermos system (or just the thermos bottle) for though.
  6. Orf
    Orf New Member
    414
    Devonport, Tasmania
    <div class='quotetop'>QUOTE(sub3marathonman @ Nov 1 2006, 03:52 PM) [snapback]342141[/snapback]</div>
    Could it be to initially heat the battery pack during winter? Or may heat his tootsies.
  7. retepsnikrep
    Hi Thanks for the interest. I know this may sound strange but I want to use the coolant heat save feature on another vehicle. The Thermos is the most difficult part to source, I can sort the rest. So I want to use it exactly for what it was designed for, to store hot coolant on another vehicle. I am not looking for a complete vehicle.
    So I'm still looking for the Thermos, Please!!!
    Thanks Peter UK
  8. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    If you know what it looks like, you might want to check with the ebay seller mentioned in this thread: http://priuschat.com/index.php?showtopic=2...mp;#entry342469
    if you read the thread, you'll see that he doesn't know what he has on hand and is pretty much making up names for stuff and trying to sell it - so it's entirely possible you can find what you need under the correct name, or a different one.
    good luck!
  9. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    I've been wondering if a failure of the coolant system pump/thermos can cause a non-start condition...?
    I'm assuming some sort of warning light would come on, right?
    Wondering also what tells the car that the pumping operation is complete...is there a level sensor, or does the pump run for a certain amount of time?
  10. sub3marathonman
    557
    75
    If I remember correctly, there were some with the EV switch that wanted to keep the thermos pump off until the engine would start up, but I don't think they were able to get that working. I don't know if the car did the error code and wouldn't go to Ready mode, or if it was just the situation that delaying the pump was too difficult, but I seriously doubt some of the experts here would have trouble doing that.
    Hopefully somebody who is an expert will supply the information. I don't see why the car shouldn't run without that system.
