What is your trip mpg on short drives? Gen 3
Discussion in 'Gen 3 Prius Fuel Economy' started by Higgins909, Sep 10, 2021.
  1. Higgins909
    Higgins909 Member
    277
    68
    So I have a 2010 Gen3 (163k at the time, 185k now) which I've picked up is notorious for bad mpg. I also figured my mpg trip meter reads +3 mpg. (At the time) I had about a 8 mile drive to and then from work 5 days a week. I pretty much got 38mpg, 42mpg being the best on my fuelly. I'm just wondering what other people get on drives like this.
    Thanks,
    Higgins909
    52,386
    i had a 7 mile commute in my 2012. around 45mpg in winter, and 55 in summer on the display.
    but there are a lot of variables
  3. Higgins909
    Higgins909 Member
    277
    68
    Wow that's amazing if it's accurate. Is it accurate to the pump/fuelly? It did not matter how I drove. I could not get past 38mpg on a tank.
  4. bisco
    52,386
    well at the time, my car only had 20,000 miles (i retired at the end of 14.
    but as i said, there are so many variables. your car has a lot of wear and tear, geography and climate make a difference, hypermiling, traffic, speed, elevations, tires and etc.
    have you cleaned the egr circuit?
  5. fuzzy1
    10,603
    #5 fuzzy1, Sep 10, 2021
  6. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    67 MPG from the last 6,400 miles. Short drives are usually 60 to 80 mpgs, almost 190,000 miles on the engine.
    dig4dirt and drbtz like this.
  7. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Define short trip. Our short trips are less than a mile for groceries. A regular trip downtown is 9 miles. A long trip is 1000 miles to the east cost.
  8. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Did 2 cold soak short trips this morning, returned using the same route in the city. Engine temp never went over 154 F, no lower engine grill block either to level the playing field. I also have a 70lb subwoofer enclosure + amplifier, LIFEPO4 12.8 pack and solar charging equipment for additional weight.
    A to B - 60 mpg
    B to A - 59 mpg
    dig4dirt likes this.
  9. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    I do not own a Gen 3 anymore, but when I would take the kiddies to school
    It was about a 1.2 mile round trip and due to the warm up stages, I would eek out 35-40 mpg during summer,
    and about 30 or so during the winter with grill block and engine block heater.
    In my Prius C, I do 3.1 mile each way to work, and I normally get 40-45 during winter and maybe 50-60 during summer
    That is a different engine and much lighter car then Gen 3 tho
    Lots of variables as mentioned already
    Grit likes this.
  10. fuzzy1
    10,603
    ... but your pictures are less than an hour apart, so I wouldn't count the second as a "cold soak". While definitely not a warmed up start, it shouldn't be really cold either.
  11. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Both engine temps at start up were the same when ready was lit up with ice about to kick on.
  12. Pdaddy
    Pdaddy Member
    160
    49
    In my 2010 I used to get 48+ in summer, but I am down to 41 mpg on the readout in summer and about 38 in winter. Been declining since 200K miles and about 240K miles now. Cleaned EGR, and throttle body, replace air intake manifold, plugs and PVC valve due to misfiring and made no difference in mileage. Also some drop in acceleration but does OK with power button to get on the highway.
    SM-G960U ?
  13. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    How's the HV Battery holding up:whistle:?
    When we had our old 2010, I noticed the decline and got the Hybrid Automotive equipment ;).
    Once I began maintaining the battery, mpg's returned :).
    One potential solution(y).
    Pdaddy likes this.
  14. MegaMix
    MegaMix New Member
    Oregon
    10 mile commutes tend to hover between 40 and 60 mpg.
  15. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    My short trip average is in the 35-38 mpg, A/C on. These are low speed 35 mph or less, 2-3 mile round trips. Highway mileage is above 50 mpg.
  16. Saucey
    Saucey Junior Member
    San Diego
    2013 with 185K.
    Route to work is 7 miles if I take the highway (65-75mph), 9.3 taking the streets home (never over 65, 20 stops max).
    get about 40-42mpg and 36-39mpg...
    I am a bit inland in San Diego, & the commute has a hills at home & at my work, so that's probably why it's bad, especially since I have a heavy foot.
    Temperature has been low 60s to maybe mid 70s.
    Leave to work 9PM via freeway, head home on the streets about 6/8AM depending on overtime.
    It needs a tune up, gotta clean out the intake manifold and the PCV + EGR things. Miss having 45mpg. Oh and it has a bad tire or wheel bearing, something on the left rear makes a sound.
    Also I have wind deflectors and a nice dented hood, might help aero tho
  17. Mendel Leisk
    41,898
    Yup, and don't miss the intake manifold. More info in my signature. ASAP... :ROFLMAO:
