Higher capacity battery mod?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by David EVD, Aug 23, 2021.
  1. David EVD
    David EVD Junior Member
    Santa Clara, CA
    2013 Prius Plug-in
    Found some threads from way back in 2012, but nothing current...
    Anyone know of a kit to add more battery capacity to a 2012-15 PIP? If I could go 30 miles on a charge I wouldn't burn any gas in my day-to-day, but every extra wh means a little less gas burned.
    I know, I know, the Prius Prime, but that is still too expensive for me.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Not practical.
    It likely would "upset" the battery handling computer, both for driving and charging.
    And the cost of the additional battery probably wouldn't be recovered during the remaining life of the car, if you only use a few ounces of gas a day in your normal commute.
    AND leaving the gas in the tank too long is not good either.
  3. bisco
    52,400
    unfortunately, there are no kits. there are a few who have done their own systems iirc, but it is hugely complicated, an extreme labor of love, and takes up more hatch space as well
  4. CartageneroHibrid
    CartageneroHibrid New Member
    Spain
    Case (Kees), PA Prius, Sarge and 2 others like this.
  5. CartageneroHibrid
    Spain
    Bms pack:
  6. bisco
    52,400
    i wouldn't want that bomb in my hatch, but i love it!:D
    pghyndman likes this.
  7. CartageneroHibrid
    Spain
    once finished in its box with its protections and ventilation it looks very good ..
    2B60FFB7792760CCBADB2460CCBA87.jpg 1F60FFB7882560CCBAEB2A60CCBA96.jpg 2960FFB82B1E60CCBB8F1960CCBB39.jpg
    Case (Kees), PA Prius and bisco like this.
  8. bisco
    52,400
    it looks very good!(y)
    CartageneroHibrid likes this.
  9. CartageneroHibrid
    Spain
    This is the forum where I started and is the information about my project:
    It does not allow me to post links! I think I'm very new to this chat ... You can search the web for "Mi Toyota prius "Fabricacion Pack ampliacion bateria"
    Someone who has more time here can post it for me.
    It is a forum in Spanish, but you can use the google web translator.
    #9 CartageneroHibrid, Sep 14, 2021
    Mike Wells and bisco like this.
  10. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    How did you connect this additional battery to the car?
  11. vvillovv
    vvillovv Senior Member
    4,332
    1,515
    NY
    @CartageneroHibrid Thanks for the project title - here are a few links.
    I can't find the xevna.es page but it might now be only at facebook or instagram.
    direct links cut and paste between []
    []https://mitoyotaprius.mforos.com/2055302/13120252-fabricacion-pack-ampliacion-bateria/[/]
    Kit de ZEVNA. Convierte tu Toyota Prius en enchufable
    there is also a kit listed for the Leaf.
    []https://forococheselectricos.com/2013/11/convierte-tu-toyota-prius-en-enchufable-o-extiende-la-autonomia-del-nissan-leaf.html[/]
  12. CartageneroHibrid
    Spain
  13. CartageneroHibrid
    Spain
  14. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    THIS IS AWESOME!!
  15. AzusaPrius
    AzusaPrius Senior Member
    2,239
    930
  16. Mike Wells
    Mike Wells Junior Member
    Ogden, Utah
    2013 Prius Plug-in
    The Nex packs are for a normal Prius, not a Plugin. As fare as I know NexPower does not sell packs for the Plugin.
    #16 Mike Wells, Oct 22, 2021
  17. Alberich101
    Alberich101 Junior Member
    Hungary
    2013 Prius Plug-in
  18. Mike Wells
    Ogden, Utah
    2013 Prius Plug-in
  19. bisco
    52,400
    5 g's for an aftermarket battery? i'll let someone else be the guiney pig
  20. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
