used Prius C has 57% battery for 30k miles
Discussion in 'Prius c Technical Discussion' started by gmrc, Jun 15, 2021.
  1. gmrc
    gmrc New Member
    Montreal
    2016 Prius c
    I got a used 2016 Prius C about a month ago from a dealer.
    The car seems to be running fine, but I noticed the battery drops very fast from 6 bars to 2 bars in stop and go traffic. Fast enough that I cant even see it lowering progressively, just dropping to 2 bars.
    I ran the Dr. Prius app and it says that the battery has 57% life expectancy. Would this be considered normal on a 5 year old car with only 50 000 km (30 000 miles) ?? I feel I could run into a battery problem in the next couple years....
    52,244
    welcome!
    no, it is not normal. is it from a toyota dealer? any warranty?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    In very slow "stop and go" traffic, the car actually uses the HV battery to propel the car and to run the AC.
    This is about the only situation where the C uses battery only to move the car.
    What you are seeing likely is "normal".
    gmrc likes this.
  4. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    My Prius C uses the battery a lot in city driving, not just to propel the car forward and power the AC.
    50-60% (or more) of my city miles are EV miles.
    gmrc likes this.
  5. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Maybe test was not done right?
    Mendel Leisk and gmrc like this.
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The app is useless garbage. It uses a few metrics but it is not a real test.
    As for a 2016 Prius C, the pack is smaller to begin with and then you now have 6 years on it (2016 is made in 2015). A Prius can drive with little change until a very low capacity. Just drive it and be happy.
    gmrc likes this.
  7. Leadfoot J. McCoalroller
    8,127
    7,624
    Pennsylvania
    2018 Prius c
    The odometer tells you how beat up the interior should be. The calendar tells you what shape the battery is in. In other words, ignore the mileage when evaluating the battery; age tells you more.
    You've probably got 3ish years before it needs a replacement hybrid battery. It could last longer, but they are notoriously difficult to predict.
    gmrc likes this.
  8. gmrc
    gmrc New Member
    Montreal
    2016 Prius c
    I redid the test and got 73% - much more satisfying ! I think It might have failed right at the end last time. Thanks for the input everyone.
    Pri3C likes this.
  9. Leadfoot J. McCoalroller
    8,127
    7,624
    Pennsylvania
    2018 Prius c
    Keep the battery fan clean and use plenty of air conditioning. The battery breathes cabin air to keep itself cool, and the cooler you keep it the longer it will last overall.
    Welcome & good luck!
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    For the second time the test is meaningless.
    As you should have just clearly proved to yourself. Unless you believe your battery self healed
    Danny13pruisc3 likes this.
  11. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    That seems much closer to the condition of a 2016 Toyota battery in a car with only 30k miles.
    I personally think the data the Dr. Prius app provides can be useful if you need to investigate a potential battery issue, or maybe you have an older battery showing its age and are about to take a road trip - it wouldn’t hurt to connect and test. My 2014 scored 88% at 45,000 miles when I bought it in April 2020. I haven’t tested it since, but I’m curious how much the percentage has dropped with another 25k under its belt, so I’ll get around to it soon.
  12. Mendel Leisk
    41,792
    Toyota has a "hybrid health check", utilizes Techstream. I believe in UK having it done allows you to extend the battery warranty? It's big in UK, but nobody seems to have heard about it in North America.
    Toyota Hybrid Health Check - Toyota UK Magazine
  13. Danny13pruisc3
    175
    27
    maryland
    Your MPG is a good indication of your battery health.
  14. Danny13pruisc3
    175
    27
    maryland
    Do invest in a toyota techstream cable and software.. and look at all your battery blocks
