What's with the passenger side tire?
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Sep 13, 2021.
  1. ASRDogman
    ASRDogman Senior Member
    7,547
    3,897
    "sam's" ha ha ha ha ha ha
    That's like asking fauci about the china virus!
    :confused::confused::confused::eek::eek::eek::ROFLMAO::ROFLMAO::ROFLMAO:
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    And THAT is getting pretty close to a blatant insult.......on a couple of levels.
    Or do I misunderstand the comment somehow ??
  3. ASRDogman
    7,547
    3,897
    My apologies! I miss read the post. I thought it said "Sam's club".
  4. Mendel Leisk
    41,340
    Join the club.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Asking whether the cup is half full or half empty yields the same result.
    People were trying to find out if the tires were rotated from side to side, which would yield a similar answer to yours...
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Going to Sam's Club now to join. Oh wait, I'm already a member.
  7. fuzzy1
    10,412
    So, by that particular reasoning, it is just fine to cross-rotate IF the tires lack directional arrows. Right?
    Both of my Priuses came from the factory with tires lacking directional arrows.
  8. sam spade 2
    7,035
    2,801
    2017 Prius c
    I don't know.
    Do ALL "directional" tires have arrows embossed in the sidewall ??
    I would hope so......but maybe not.
    It is "just fine" to follow the directions.
  9. Mendel Leisk
    41,340
    I'm truly sorry I asked OP if he followed the Owner's Manual instruction for tire rotation, 'cus here we are...
    Guess if it wasn't that, it'd be something else... :rolleyes:
  10. burrito
    burrito Active Member
    274
    114
    You know, there are many problems in this world, but I'm pretty sure you're not one of them.
    You keep being you, @Mendel Leisk.
  11. fuzzy1
    10,412
    If some directional tires don't have an arrow embossed in the sidewall, then they must have some other method(s) of signaling to owners and tire installers which side of the vehicle they must be placed on. What might that signal be?
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    My last set of tires would lose 1 psi per week with 3 mm of tread left, the tires were 4 years old. The psi lost happened on all 4s. When the tires were new, I only experienced 1 psi drop per month. You may have check tire age and measure tread height.
