Bleeding the brakes before fixing brake actuator
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jason Packel, Sep 13, 2021.
  1. Jason Packel
    Jason Packel Junior Member
    53
    Orlando, Fl
    Hi. My Toyota dealership said I need to repair my brake actuator on my 2007 Prius. The lights haven't come on yet though. Does it make sense to bleed the brakes first to see for sure if it is the actuator? It should only cost $95 to bleed the brakes. Thanks in advance.
  2. JC91006
    JC91006 Senior Member
    16,759
    8,562
    If you can hear the actuator keep cycling when you turn off the car (like every 15 seconds), then you will soon have a failure of that part. I changed out my actuator when it started cycling more than normal.
    I don't believe the brake bleed will help this situation but I believe the repair manual does suggest that being the first step to take.
  3. ChapmanF
    18,006
    Can you give a little bit more of the background? Why were you at the dealership? Were you there to ask about some brake concern that you had, and their answer involved the actuator? Or were you there for some other reason, and they said "we noticed about your actuator...."?
    If you were there to ask about a braking concern, what was your concern?
    And either way, what did they say about the brakes?
  4. Jason Packel
    53
    Orlando, Fl
    Hi ChapmanF, thanks. I went to the dealership because there was a mild grinding from the brakes. I thought it was just simply getting the brakes done. They said the brake actuator needs to be replaced. The lights aren't on yet though. They quoted me at $2600, and said the brake lights would come on relatively soon.
  5. ChapmanF
    18,006
    A mild grinding noise that you hear from the wheels while braking is not the kind of symptom that would normally lead me toward the actuator. They might have noticed something about the actuator additionally, while they were checking out your grinding noise.
    Did they say anything specific about what they noticed regarding the actuator? Also, did they say anything about the grinding?
  6. Jason Packel
    53
    Orlando, Fl
    I see what you are saying. They didn't say anything about the actuator, just that it needed to be replaced. They did say though that the brakes are fine, they aren't worn down. They didn't say what they thought the grinding was.
  7. ChapmanF
    18,006
    Beautiful. Didn't answer the question you went in for, and didn't say why they brought up something else. :giggle:
  8. Jason Packel
    53
    Orlando, Fl
    Right, I should have asked, I just didn't know what a brake actuator was when they told me. Do you think it makes sense to bleed the brakes first? Someone said that it might be the first thing to do - saving me from installing a new actuator.
  9. ChapmanF
    18,006
    I would start by giving them a call to try and find out if anybody there still remembers what they saw or heard or read on a scan tool or noticed that led them to mention actuators or bleeding to you in the first place.
  10. Jason Packel
    53
    Orlando, Fl
    Sounds like a good idea, thanks so much!
