Miles to empty
Discussion in 'Prime Main Forum (2017-2022)' started by hatcher8, Sep 17, 2021.
  1. hatcher8
    hatcher8 Junior Member
    32
    Lincoln Ne
    I've had my 2017 Prime for 4 years now and have never found the "miles to empty" display. Where the heck is it? Is their one?
  2. schja01
    schja01 Senior Member
    1,848
    1,228
    Chicagoland
    2024 Prius
    Limited AWD-e
    It’s one of the trip odometers. Just repeatedly press the TRIP button on the steering wheel. Distance to empty is the display with the gas pump.
    Raytheeagle and hatcher8 like this.
  3. hatcher8
    32
    Lincoln Ne
    Thank you
    jerrymildred likes this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Just FYI, the DTE (distance to empty) miles is for gas-only operation. If you are driving on EV mode and charging the car repeatedly without using gasoline, then DTE will remain the same. It is also not really to the "empty" but till when the fuel light first comes on, at which time there is 1.5 to 2 gal of fuel still left in the tank.
    Read this thread if you want to more about the use of the DTE for estimating HV only milage.
    What is your DTE after fill-up? | PriusChat
