First service on a 2021?
Discussion in 'Prime Main Forum (2017-2022)' started by Prime_Time, Sep 20, 2021.
  1. Prime_Time
    Prime_Time Member
    110
    74
    Southern California
    Picked up our 2021 about 6 months ago and we are at about 4,700 miles. When we start the car we get a "Maintenance required soon message". I looked up the maintenance schedule in the manual and it shows the first oil change at 10k miles or 12 months. It lists the following at 6 months or 5k miles:
    Check Installation Of Driver's Floor Mat Inspect HV Battery Cooling Intake Filter1
    Rotate Tires Inspect /Adjust All Fluid Levels2
    Inspect Wiper Blades Visually Inspect Brake Linings/Drums And Brake Pads/Discs3
    Do we need to take it in now to avoid for these minimal services to avoid voiding our warranty or is it ok to wait until the first oil change at 10k miles / 12 months?
  2. Mendel Leisk
    41,335
    Once more, into the void? ;)
    The 6 months or 5K mile service is free for you, right? If you want to keep a clean, unarguable record, I would bring it in.
    FWIW, I never had dealership service on ours. There's no 2 years of freebies deal up* here in Canada though. Maybe for the best. I do keep a log, all receipts, buy virtually all supplies through dealership parts department, like oil filters and oil. And the purchases are registered to my name and the car VIN.
    * I guess it's not really "up", more like "over a bit, to the North"?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Do you really think that failing to inspect the floor mats, rotate the tires, inspect the wiper blades and inspect the brake pads will somehow void some part of your warranty ???
    It won't. Tires and brake pads are "wear items" and basically have no warranty anyway.
    I split the interval on both my cars. One visit around 7K miles.
    I never take it in JUST for a tire rotation at 5K.......unless maybe I suspect a problem with the tires.
  4. Trollbait
    12,507
    These are all things you can do yourself, or have an independent shop do if you aren't the type to be jacking up the car and swapping wheels around. Once you are out of the free maintenance period.
  5. Salamander_King
    Salamander_King Senior Member
    11,016
    8,947
    New England
    As already commented, skipping the 5K service will not void the warranty on the car. Although I have never heard of the actual case, hypothetically, skipping the 10K oil change and somehow you end up needing to get warranty service on your engine, and if you can't produce the proof of service for the oil change, it is possible they may deny the warranty service if it is determined to be caused by neglect.
    However, skipping the 5K service may in fact void the tread warranty on the OEM tire if rotation is not performed. You can look at the small print that came with the manual. The OEM tires have a separate warranty from the tire manufacture. Usually, it does not have a "tread" warranty like the one you find on the aftermarket tires, but you may need to check the terms of warranty for your specific OEM tires.
    Otherwise, for 5K service, you can just check fluid levels and do the tire rotation yourself... or as long as it is not inconceivably inconvenient for you, just take the car to any Toyota dealer for a free Toyota Care. That's what I usually do for my first 5 services.
  6. Mendel Leisk
    41,335
    Especially that floor mat check. :rolleyes:
    The freebies aside, you are allowed to basic maintenance yourself, if you’re so inclined. Do keep good records, and all receipts.
  7. Trollbait
    12,507
    For now.
  8. Mendel Leisk
    41,335
    I was going to say just that, skipped my mind. (y)
  9. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    If you're wanting to change the constant reverse beeping to on single beep upon reverse engagement, then your 5k service can be used for that. Dealership should do it for you at no cost :)
  10. Mendel Leisk
    41,335
    I’ll be @Grit :
    o_O
    Raytheeagle and dig4dirt like this.
  11. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Mr. Time (may I call you Prime?), somewhere in the back of your owner's encyclopedia you'll find a list of the options only the dealership can change for you. The back up sound mentioned above is just one of those. You might look at the list and see if you'd like anything else changed to your preference.
    I like to get the first service performed at the dealer. There might be things the usually sloppy predelivery work skipped (tire inflation pressure one well known skip), and there might be updates for the car's systems.
  12. Prime_Time
    Prime_Time Member
    110
    74
    Southern California
    I've already fixed the beep using my ODB dongle dangle. If anything, I'll take it in just to get the reminder removed from the dash as I have to click out of it every time I use the car.
    Marine Ray and dig4dirt like this.
  13. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    You the owner, can reset that maintenance reminder....
    ...again in the owners manual or other literature might have it too in the glovebox.
    Just a little scrolling thru the menus on the screen.
    I cannot say if same as XLE that I own vrs the LE trim level
  14. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Maintenance Reminder Reset:
    jerrymildred likes this.
  15. ETC(SS)
    7,136
    It's not "free" down here either...unless your time is of no value, and you don't fall for some of their antics.
    The only reason that they get away with these scams down here is our consumer protection laws allow outright thievery at the dealership service departments,
    I wonder how???? ;)
    I will ONLY let the dealer touch MY car when all lesser means have failed.....and I take great pains to make sure that this almost never happens!!
  16. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    Tire Rotation - for android Tire Assistant will give you serial #'s of the TPMS sensor locations as programmed into the specific ECU. Makes it easy to check if the rotation was actually done. I finally got our first rotation service completed at 30k. I don't ask but do tell.
    5k service the car was washed but was missing a TPMS sensor cap when I got it back.
  17. Mendel Leisk
    41,335
    Simpler, just put a felt marker dot on the rim backside of the two rear wheels, say near the valve stem, to facilitate locating them later.
    TPMS sensor cap? That's a tire valve cap, right? ;)
  18. Gokhan
    Gokhan Senior Member
    6,153
    2,433
    Paramount CA
    First service should be performed six months after the date of manufacture—not the date of purchase—and the second service one year after the date of manufacture—again, not the date of purchase. They are not optional. They will void your warranty, damage your CarFax report, and decrease the resale value of your vehicle if they are not performed.
  19. sam spade 2
    7,035
    2,801
    2017 Prius c
    Total BS.
    Where exactly did you get that idea ??
    You have it exactly backwards.
    No reason to do a "first service" on a vehicle that has been sitting on a dealers lot for 6 months.
  20. Gokhan
    6,153
    2,433
    Paramount CA
    In your opinion.
    Do whatever you want. Don't change the oil at all if you like.
    The cars get to put in first service when they leave the factory, not when they are sold. In fact, during the first five miles or so, the car is driven several times for very short distances around the ports or in the Ro-Ro without fully warming up, and/or it is idled a lot—falling into the most severe service category. That's why, following the one-year time rule, logically, you should change the oil one year after the date of manufacture, not the date of sale—even if the warranty doesn't legally require it, as that's the right thing to do for the proper future health and longevity of your engine.
    This was also discussed in another car forum.
    First service interval: 1y from manufacture, arrival on dealer lot, or delivery? | VW Vortex—Volkswagen Forum
    #20 Gokhan, Sep 21, 2021
