Tie rod sheared off!
Discussion in 'Gen 3 Prius Main Forum' started by BIG Ne, Sep 10, 2021.
  1. ChapmanF
    18,585
    That's the part for a 2009. The OP's profile does say 2009, but post #1 does also say "Gen 3" and this is the Gen 3 forum. I cannot find the inner rod (from Toyota) for a Gen 3 (see figure in #9). It seems that between Gen 2 and Gen 3, Toyota decided not to offer the inner tie rods separately. (They are available aftermarket, as BZzap! showed in #15.)
    So I'm not totally sure what the OP's car is. Is it a Gen 3? Is it a 2009? DId Gen 3 start in 2009 in the UK? I'm not sure.
    While I agree with BZzap! that it looks like only the tie rod broke, and could probably be replaced, there is a nagging question in my head about just why it broke like that, inside of a year. I wouldn't want to see it happen again.
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    One can only guess as to how that tie rod broke. I do know that where it did break, is the weak link. At the very end of those thread is a definite stress riser due to the manufacturing process. Is it a defective part? Maybe…but I think something else exacerbated the failure. The tie rods don’t have much side load stress. They work in a linear plane.
    The only other thing I can think of, is the ball socket is at the end of the rod is heavily corroded and frozen up. After a while this would work the tie rod to the point of failure…at the weakest point.
    #22 BZzap!, Sep 13, 2021
    BIG Ne likes this.
  3. BIG Ne
    BIG Ne Junior Member
    United Kingdom
    Active
    Update from garage,
    He's unable to source just the inner tie rod from his suppliers, he can get the steering rack kit for £500($680). I've told him I've found an aftermarket part (German manufacturer) on eBay for £40 ($55), he's happy for me to buy it & he'll fit it, charging me for 1/2 hour labour.
    Toyota main dealer quoted me £1,000 ($1,365) just for the steering rack kit, I didn't bother asking how much for labour/installation. From previous work Toyota did on my car, I know they charge £120 ($165)per hour for labour!
    It seems like this is not a common issue/fault so there isn't a huge supply or demand for this part, at least in the U.K.
    Need to decide whether to keep the car or get rid of it as it turned into a money pit.
    Thanks to everyone for advice/input. I greatly appreciate it.
  4. Gliderguy
    Gliderguy Junior Member
    46
    Prescott Valley, AZ
    Just be careful what country you source the part from. Here in the States cars are driven from the left side of the vehicle on the right side of the road. I know England is right hand side drive driven on the left side of the road. It is not clear to me that the steering rack is reversible to work for both situations. I strongly suspect it is not and that would limit what places you want to procure one from...
    BIG Ne likes this.
  5. Gliderguy
    46
    Prescott Valley, AZ
    Does the car have the orginal wheels/rims? A hard hit to a curb might have overstressed the steering box components, but I think any hit hard enough to break that would have destroyed a rim. Probably wise to do a close look inspection specifically looking for signs of a hidden accident from the previous owner. I am not sure about England but in the states we have several services, one is called CarFax that can track the repair history of a vehicle by the VIN number. If it had ever been titled as a salvage vehicle that would show up, or at least in the States it would. I am not sure how that kind of information might be recorded differently in England.
    BIG Ne likes this.
  6. Mendel Leisk
    41,941
    BIG Ne likes this.
  7. BZzap!
    1,607
    878
    Sorta like taking you dog to the vet. Such a simple job to take advantage of a lay person. This is why people don’t trust mechanics like these. They are nothing more than predators!
    BIG Ne likes this.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,000
    NJ-USA
    Wow. Been fixing cars for almost 32 years and have never seen a failure like that. Can't even imagine HOW that could happen (defect in the part?). Any shock to the wheel would likely bend the steering knuckle, bend the tie rod, or break the rack- such a force would be trying to compress the inner tie rod.
    If you tried to pivot the inner joint way beyond its normal range of movement, you might be able to snap it, but that can't happen unless something else first broke completely.
    BIG Ne likes this.
  9. BZzap!
    1,607
    878
  10. BZzap!
    1,607
    878
    My theory: post #22
  11. BIG Ne
    United Kingdom
    Active
    Hello,
    It has the original wheel/rims, I've not had a hard knock or impact against any kerbs. The previous owners had it serviced/maintained by Toyota dealership it was brought brand new from. I believe there is a premium service where you can pay to see the cars complete history (if ot was involved in an accident) but I didn't as I could see it's service history & MOT history (yearly leagal roadworthy check). If it was involved in a crash & deemed too costly to repair by insurance company then it would be flagged up when I took out insurance for it. It's possible it was involved in an accident, the parties involved decided not to get their insurance companies involved & exchanged 'cash in hand' at which point my insurance company wouldn't be aware of it's status, I would hope that sort of thing would be picked up in the MOT & servicing.
  12. bisco
    52,414
    you have a pretty tight system. here, you can never trust a used car history. way too many scammers continually outsmarting the establishment
    BIG Ne likes this.
  13. BIG Ne
    United Kingdom
    Active
  14. bisco
    52,414
    is it rust?
  15. BIG Ne
    United Kingdom
    Active
    On which part?
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    I would get both front wheels off the ground start the car put it in park and do
    A turn the steering wheel end to end see if it feels ok then with someone turning the wheel watch that bad end see if it’s smooth in and out.
    Put your hand on it feel for grinding or unsmooth motion as it articulates.
    It may not show an issue unloaded but if it does not look smooth in and out unloaded you’ll know the rack is jacked too.
    Never seen this injury on a car that wasn’t in a bad frontal.
  17. bisco
    52,414
    the tie rod
    edthefox5 likes this.
  18. BIG Ne
    United Kingdom
    Active
    Didn't look like rust to me.
  19. bisco
    52,414
