Symptoms of dead 12V but charger says battery full?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by berderder, Sep 22, 2021.
  1. berderder
    berderder Junior Member
    61
    Connecticut
    Hi everyone,
    I've been having what appear to be dead 12v battery symptoms in my Gen 3 (2014). Dim interior lights, trunk locked and can't be opened unless manually, of course car not starting. I took the battery out and hooked it up to a cheap charger from Walmart. The charger reads that the battery is fully charged. Am I missing something?
    Other symptoms: cannot lock any doors, that big orange triangle indicator on the dash
    Thank you for any tips you can give
  2. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    The phenomenon is called "surface charge". After driving around some or charging with the charger, (turn off the vehicle or disconnect the charger), turn on your high beams for 30 seconds. Afterwards measure the voltage at the battery terminals and report.
  3. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Load test it.
  4. berderder
    61
    Connecticut
    Oh, I cannot even start the Prius
  5. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Auto parts stores does test loads for free, your car can’t do test loads. Some will even charge battery for free.
    berderder likes this.
  6. berderder
    61
    Connecticut
    Thankfully there is a little garage in walking distance I can take the battery to. Might have to do that first thing in the morning so I can make my day appointments. Not sure if leaving my battery plugged in while the charger says it's full is a good idea
  7. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    If your 2014 has its original 12v auxiliary battery, then it's time to replace it anyway. It's 7 yrs old, that's a good run for an oem battery.
  8. berderder
    61
    Connecticut
    Yeah that's true. I'm the 2nd owner and double checked my service history in CarFax - doesn't look like battery was ever replaced. I guess the other thing is it seems like it happened out of nowhere, car is in regular use and didn't give me any sign that the battery might be failing. I suppose that might just be how it is, I'm not super versed in this
  9. berderder
    61
    Connecticut
    Any battery replacement recommendations?
  10. rjparker
    7,605
    4,464
    Any recent charger should regulate enough to leave it on overnight. What model is the charger?
    Generally you need a charge on the battery to load test it. Unless it is absolutely dead and won't take a charge. Its doubtful a garage will have a Prius battery so they would have it delivered. There won't be many options, maybe one brand at an auto supply or the Toyota OEM (best if in stock) at the dealer.
    #10 rjparker, Sep 23, 2021
  11. berderder
    61
    Connecticut
    This is the charger I have:
    Everstart Maxx 3 Amp 6V/12V Automotive Battery Charger (BC3E) - Walmart.com
  12. rjparker
    7,605
    4,464
    I would put that charger on overnight. Be sure its set for 12v. Its possible the car might go to Ready in the morning if there is any hope for the battery.
  13. berderder
    61
    Connecticut
    I’ll give it a shot, thanks. I’m just confused why the charger says the battery is already full and am afraid of overcharging it
  14. xliderider
    7,848
    3,102
    Honolulu, HI
    FYI, our oem battery didn't give any signs of failing either, until we couldn't unlock the door using the sks, or keyfob,and the car wouldn't start or go into Ready.
    jzchen likes this.
  15. rjparker
    7,605
    4,464
    In the morning, be sure to try three times if it does not go to Ready. Power off between tries. Often necessary after a total discharge. Even if it runs, go directly to an auto supply and have it checked.
    jzchen and berderder like this.
  16. berderder
    61
    Connecticut
    Yep, exactly what happened to me. I guess that's just how it can happen
  17. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Did you check the connection of the ground wire from the battery to the car body? It doesn't matter how good the battery is if that's loose or corroded.
  18. berderder
    61
    Connecticut
    After I went back into the trunk I noticed about a half inch of oily liquid at the bottom of the battery compartment. Yeesh. I used gloves and cleaned it up with rags - the liquid didn't smell like anything, just water. Probably shouldn't have smelled it lol.
    But yes, otherwise the contacts looked pretty good. Clean and the battery itself was dry, unlike the floor of the compartment. After about 4 hours of the battery being hooked up to my charger in the basement, the car still didn't start after reinstalling. I am now looking at possibly picking up a new TrueStart battery to replace it.
    I spent the majority of winter in very very cold Vermont, I think that probably knocked some time off its lifespan
    jerrymildred likes this.
  19. Mendel Leisk
    38,247
    yeah I doubt your charger is a capable tester. Don’t conflate the charger being “done”, with the battery being “good”.
    if you want to DIY the load tester, look into Solar BA9 for one.
    berderder, jerrymildred and jzchen like this.
  20. jerrymildred
    11,491
    14,100
    Tampa, FL
    I just put a new Truestart in my wife's 2017 a couple days ago. Since the Gen 4 battery is lead acid (wet) it probably cost less than the AGM you'll need to get. Mine was only $180 minus a $10 coupon.
