After 11 Years she finally ran out of gas on me and then this happened
Discussion in 'Gen 3 Prius Fuel Economy' started by GoliathMV, Sep 22, 2021.
  1. GoliathMV
    GoliathMV Member
    69
    33
    New York
    You are reading correctly my friend I let the dang car run out of gas and thought exactly what happened to me would happen. So yup when the ole girl runs out of gas she fights tooth and nail to keep the systems operational and even tries to use the traction battery to get you moving for as long as she can. My problem was that I had left the dang car on Eco-Mode so every chance the car got she uses the traction battery. After 11 years I have decided to let the system run on normal simply by just clicking the eco-mode button again to disable the mode. This car is just amazing and I honestly will never ever ever get rid of this car even if Tesla gives me a car free for trading it in for a model Y Dual Motor extended range. Elon Call me.
  2. fuzzy1
    10,602
  3. Grit
    Grit Senior Member
    6,576
    4,228
    Wilkes Land
    That was it?????!!!!!!!
    fotomoto likes this.
  4. bisco
    52,349
    what happened?
  5. Mendel Leisk
    41,860
    Nothin much?
  6. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "Nothin much?"
    Essentially a version of automotive Russian roulette (FacePalm...)
  7. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    I don't know what annoys me the most...folks who let their vehicles run out of gas or folks who don't change their engine oil regularly. I just saw the insides of a ruined Prius ICE engine because the owner drove for Uber and only changed the oil every 10,000 miles "or so". Those pistons were NASTY. I fill my vehicles at 1/2 a tank when it's cold (winter) and at 1/4th of a tank any other time.
    That has to be dumbest thing Toyota does...telling folks our ICE engines only need an oil change every 10,000 miles. Well, yeah, IF we only plan on keeping our car for 4-5 years (which is considered "lifetime"). So when we read the transmission/cvt oil is "lifetime" it really should say, "Needs changing every 4-5 years."
  8. bisco
    52,349
    i ran out once. not intentionally, but the gen 2 only gives you a quick beep and then the blinking bar which is easy to miss.
    i heard the beep, but forgot about it after arriving at my destination. then, i ran out a mile from home a few days later.
    drove on battery until the dash lit up and the car died. walked home and called aaa the next day.
    they put a few gallons in, she started right up, and i was off. i try to put in a few gallons now when i'm down to one bar.
    with the pip, you don't want your gas to go stale, it's a double edged sword.
  9. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    Wow, Bisco, I didn't think about gas going stale in a PIP Prius! I guess it starts to degrade after just 3 months so it would be smart to not fill it up if you don't use it all in that time frame. Maybe adding a little gas stabilizer wouldn't be a bad idea and maybe running some fuel injector cleaner through the ICE a few times a year. (I run the cleaner in all my vehicles every month or so.)
  10. fuzzy1
    10,602
    According to the 2012 PiP Owner's Manual, he needn't worry about it for 6 months:
    The Prime boosted this time interval to 12 months.
    Remember that fuel systems on PHEVs are far better sealed than on any other cars on the market, so their fuel goes stale slower. GM and the other car makers and CARB worked together to design fuels systems for these vehicles:
    "... but now we've got the scoop on the gas tank used to keep liquid fuel in the Volt from evaporating or going stale for up to a year. "
    How designing the Chevy Volt's sealed gas tank brought automakers, CARB together | Autoblog
    dig4dirt likes this.
  11. bisco
    52,349
    since spring of 2020. our driving like many others has been severely curtailed. i don't like burning fuel just because it is old. so i only get 2-3 gallons at a time.
    i use more gas in my riding mower these days :p
