2018 Prius touring four - needs new tires, help! Drive 80miles, 5x a week.
Discussion in 'Gen 4 Prius Main Forum' started by Prius2018SH, Sep 22, 2021.
Tags:
  1. Prius2018SH
    Prius2018SH New Member
    Raleigh, NC
    2018 Prius
    Four Touring
    Hi - I drive a 2018 Prius touring four - needs new tires, help! Drive 80miles, 5x a week. Not going to the dealership they offered me 4 tires for $1000 and the ones they recommended I'm not sure I want. Anyone suggest good tires for driving a lot of miles a week. I live where it rains a lot. Thank you for any help.
  2. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My favorite Prius tires are Nokian WRg4. They will last 60k miles, are strong tires (H-Rated) have a low rolling resistance, and good in wet/snow. I get them locally for about $500 a set.
    JeffD
  3. Merkey
    Merkey Active Member
    315
    283
    Birmingham, Michigan
    Michelin Defender T + H at Costco.
    Mambo Dave and Prius2018SH like this.
  4. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    I second costco but but dont recommend Defender
    Prius2018SH likes this.
  5. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    I think Pirelli P4s are the treadlife warranty leader presently.
    I had Michelin Harmony on a 06 civic that lasted over the 90k warranty. I replace the Primes OE Toyos with Defenders, but I've already lost 3/32s of tread in 15k miles, so I'm not expecting to get 90k miles from them.
    But the Defenders offer quite a bit better handling and grip than the Toyo s. But to get that better grip on the road the tire sacrifices a tiny bit of MPG's with a higher rolling resistance.
    If the rain is really bad the Defender LTX 205 65R 15 for Light Truck and SUV has wider treads and 50lbs inflation limit and 99 T weight and speed rating and has 1/2 inch larger diameter and is a smedge wider than the defender T H 195 65R 15 with 44lb inflation limit.
    I think I'll be trying out the Pirelli P4 next time.
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
  7. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Not sure if you get much snow but we replaced the Toyo OEM tires on my wife's 2017 Prius with General Altimax RT43's. They have a 65,000 mile warranty and with road hazard and free rotations ran me $479....WAY cheaper than what you were quoted! Give them a try...they also give military discounts if you are a Vet.
  8. Mendel Leisk
    41,315
    I "think" OP's got 215/45R17, and IIRC Defenders don't come in that size. Would help if @Prius2018SH clarified.
    #8 Mendel Leisk, Sep 23, 2021
  9. Prius2018SH
    Raleigh, NC
    2018 Prius
    Four Touring
    I just called Costco and they recommended the Michelin - Cross Climate.
    dbat23 likes this.
  10. Prius2018SH
    Raleigh, NC
    2018 Prius
    Four Touring
    Yes, my tire size is P215/45R17. I was just recommend the Michelin Climate Control at Costco. They are having a deal on Michelin, but not sure if those are good tires. Thanks!
  11. Merkey
    315
    283
    You are correct. Costco's website doesn't list the Defender in the 17 inch size.
    Maybe try the new Cross Climate 2?
    Mendel Leisk and Prius2018SH like this.
  12. Mendel Leisk
    41,315
    I went with Primacy MXM4 (in 215/45R17). They've been good, but there was a significant dip in mpg right after install. It's come back more-or-less now. Previously (the one the car came with) it had Michelin PIlot hx MXM4.
  13. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    I bought the Bridgestone Turanza Quiettracks at Costco for mine, but now think I would have liked the Michelins more. I bought the Turanzas for the open side sipes since we get torrential tropical rains, and for that they've been great. I can't quite call them quiet on the local roads though.
    #13 Mambo Dave, Sep 24, 2021
  14. Recian
    Recian Junior Member
    61
    22
    New Bern, NC
    I run a Hankook Kinergy GT and I drive 110 miles a day 5-6 days a week. They get the same mpg as my stock tires, around 54 and they seem to be wearing good and are quiet. $65 each for 15s and ~$130 EACH FOR 215/45R17 (TOURING tire size) I have some brz 17s I'm planning to run so last time I priced the 215/45R17 Hankook it was 128
  15. Ramo_958
    Ramo_958 Junior Member
    22
    Doylestown, Pennsylvania
    2018 Prius
    I just bought a set of Continental TrueContact. So far so good, the gas mileage dropped from 57 to 55 MPG.
  16. Merkey
    315
    283
    Good tires. Your MPG should improve in a few thousand miles.
    Mambo Dave and Ramo_958 like this.
  17. jdenenberg
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    These tires roll about 831 revs/mile (for new 195/65R15 size). Check the revs/mile for your original tire as that affects the calibration of the odometer/speedometer. Note that as a tire wears the revs/mile increases and the apparent MPG increases.
    JeffD
    Ramo_958 and jzchen like this.
  18. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    I put Hankooks on my truck. They needed balanced every 4k miles or so. Was not entirely impressed.
  19. dbat23
    dbat23 Member
    53
    37
    WI
    2020 Prius Prime
    Getting installed at this moment
    Mendel Leisk and Mambo Dave like this.
  20. Mendel Leisk
    41,315
    Review (the Cross-Climates) when you've got a chance?
    I'm in the separate-snow-tires camp, but lots want a one-set-solution. Interesting tire; tread pattern very distinct.
