Yearly brakes cleaning recommended?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Nico3d3, Sep 26, 2021.
  1. Nico3d3
    Nico3d3 Junior Member
    37
    Quebec
    Is a yearly cleaning of the brakes good enough? On my 2014 Corolla, I neglected it. I never cleaned them but, still they worked great even after 32 000 miles. On a Prius, I'm not sure, I'd dare doing the same since they aren't used as often... I fear the caliper pins could seize. What are your thoughts and how long of a job will it be if I do it myself?
  2. Mendel Leisk
    41,879
    Toyota USA sorta* says to do a more in-depth brake inspection, every 30k miles or three years, whichever comes first. No big mystery; it’s spelled out in the Warranty and Maintenance Booklet. If that’s missing, you can download a PDF from Toyota Tech Info, in the Manuals Tab.
    * It’s vague as hell, but there; look through the various intervals, note the absence of “visual” inspection and addition of instruction to check rotors, every 30k.
    jerrymildred and bisco like this.
  3. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    First time I did it on my 2007 was at 148,102 miles. Cleaned & relubed the guide pins. None were totally seized but they did work a bit more smoothly after. Pads still had lots of meat on them!
  4. Nico3d3
    37
    Quebec
    That's great to hear, I had so much troubles with brakes on a Kia Rio. People told me it was because brakes need cleaning at least once a year. Now, I know that wasn't completely true, it's only true with shitty Kia or Hyundai car.
  5. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    How long it takes depends on what you find when you get into the job, and how nit picky you want to be about doing the job. Anywhere from a hour or two on up.
  6. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    Cleaning of brake(s) periodically or otherwise is not needed, but nice to have for some folks more so for DIY's.
    Does brake 'cleaning' helps in longevity ? I don't think so for a normal performing brake system.
    Does it help in immediate efficacy of brakes, may be it does as I don't practise it.
    Had anyone of several 'rare' occasions of 'accidents' I encountered solely caused by lack of so-called brake cleaning? No.
  7. Nico3d3
    37
    Quebec
    Yes but, prior to my Prius and my Corolla, I had a Kia Rio. I had to replace rear brake pads and discs twice in two years. People always told me it was because I didn't take care of them. Those korean cars are just shitty econoboxes.
    zeng likes this.
  8. ChapmanF
    18,521
    It may come down to what a person means by 'cleaning'.
    Me, I'm not especially interested in whether my brakes look nice.
    I do, on the other hand, flip them up every time I rotate the tires, measure the pad thicknesses, check that the rubber boots are not damaged, and push the calipers in and out on the slide pins to wake up the grease.
    I never bother taking the slide pins out or regreasing them unless just waking the grease up doesn't work or their movement feels rough. So far in the history of my 2010 that means actually never. In the time I had my 2001 I may have done that once.
    I have replaced 'fitting kits' (the little springy teflon-coated bits the pad ears fit in) a little bit more often than that.
  9. Mendel Leisk
    41,879
    Akin to "do you need your teeth periodically cleaned"?
  10. vvillovv
    4,324
    1,512
    NY
    I spend more time trying to keep the silly mags clean than I do cleaning the brakes. Love the grovey mags. I do keep a can or 2 of brake cleaner in case of emergencies like when I get my fingerprints on the rotors. Don't want the brake police dusting for prints.
  11. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    With your previous 'nasty' experience with a Kia, I can see where you are coming from.
    Whilst a Kia's built quality may be an issue in the old era, I wouldn't rule out poor installation/replacement workmanship either.
