2010 Prius makes loud noise and now will not crank
Discussion in 'Gen 3 Prius Main Forum' started by badprius, Sep 26, 2021.
  1. badprius
    badprius Junior Member
    arkansas
    2010 Prius will not crank. I got it to crank one time and it had a horrible rumbling sound then it smoothed out running. So, I let it run about 10 minutes, then I turned it off and now it will not crank again. I checked all the fuses. And the 12 V battery is good
    #1 badprius, Sep 26, 2021
  2. rjparker
    10,298
    6,442
    Does it go to Ready? What is the voltage on the 12v battery? Do you have Check Engine or other warning lights? Do you have an OBD2 code reader?
    As a new member your responses will be delayed from our view as the moderator checks your first five posts.
  3. Krall
    Krall Member
    125
    37
    NY
    Did it sound like this?
    badprius and privilege like this.
  4. Mendel Leisk
    41,706
    How many miles?
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    How did you determine that 12v battery is good?
  6. badprius
    arkansas
    I had the 12 V battery checked. They said the battery was good but it needed to be charged. So they charged the battery. I put the battery back on and it did the same thing. I do not have any other warning lights on. I checked all the fuses. I checked the oil and all of the other fluids. And no I do not have an OBD2.
  7. badprius
    arkansas
    Yes it goes to ready
  8. badprius
    arkansas
    209k
  9. badprius
    arkansas
    That is absolutely the sound that it makes. Exactly
  10. badprius
    arkansas
    I took Out of the car and took it to O’Reilly’s parts store. They put it on their tester. They said it needed to be charged and I charged it for 45 minutes. I put it back in the car. And the car was still knocking like that. And then the car would not restart
  11. badprius
    arkansas
    I’m going to change the plugs and see if that will work I will keep you posted. Thank you for that wonderful video
    Krall likes this.
  12. rjparker
    10,298
    6,442
    The typical severe knocking and rattling on a 2010-14 is usually a head gasket failure. Especially if it happens on a coldstart and clears after a few seconds or a minute. Liquid gets into the cylinder and fouls the plugs. A lot depends on how long this has happened. When its bad the passenger side coolant reservoir will start going low. Usually no coolant in the oil or white smoke. White smoke means it is extremely bad.
    Most likely disconnecting the 12v battery for a minute will reset errors. It needs repair now. If the engine was burning a lot of oil, also common, it needs another engine, ideally a lower mile rebuilt.
    Don't spend a lot of time changing parts without first determining if its a headgasket with a borescope. Here is what can happen if you decide to wait and see.
  13. privilege
    privilege Active Member
    659
    169
    Birmingham
    are you shutting the car off, before it has finished it's first warm up cycle ?
    you can have weird knocking if the engine hasn't finished it's first warm up, and is shut down while it's running.
    otherwise, I would expect a head gasket in it's future. don't continue to use the car if the head gasket is failing, it will fail catastrophicly , and cost more to replace the entire engine, instead of just the head gasket repair
  14. ETC(SS)
    7,266
    That's the Prius "Death Rattle."
    It's just possible that you can fix this before the gasket lets go.
    I'd check the oil for signs of coolant contamination, if it's clear I'd consider looking at the EGR circuit.
    If you do not know what this is, do some reading.
    You may be experiancing the first twinges of an event caused by the automotive equivalent of a clogged left anterior descending artery (LAD).
    It sometimes goes by a less geeky nickname:
    The Widowmaker.
    The pattern usually goes something like rattle...cylinder misfire code...change plugs, change coil packs, change owner (or...engine)
    If you decide to get the plugs anyway, get them from dealer stock or a large parts house.
    There are a lot of fake Densos out there....especially from the Amazon.
    Of course....if I'm right, then the knock-off plugs will be good enough for your purposes.....
    Good Luck!
    #14 ETC(SS), Sep 28, 2021
  15. Mendel Leisk
    41,706
    Likely head gasket failure in progress, aided and abetted by clogged EGR, with assistance from PCV effluent. See my signature for more info on dealing with that.
    I'd get a leak-down test done, as soon as practical, hopefully before a piston arm gets bent, or the damper between engine and transaxle breaks. Plus the previously mentioned boroscope inspection is good,. Cylinder one or cylinder two are the usual culprits (cylinder count starts from "front" of engine, end opposite the transaxle and inverter).
  16. bisco
    52,130
  17. badprius
    arkansas
    [​IMG]UPDATE. It was the plugs. I just changed them. Took forever but it’s done. Motor runs perfectly idles perfectly. No loud banging noise. And the weird thing about it is I don’t have any hybrid caution lights on anymore. I have not been able to get those caution lights off for a year.
  18. badprius
    arkansas
    You saved me with this video! Thank you. It was the plugs!
  19. ChapmanF
    18,352
    The often-overlooked AECS story strikes again!
    (y)
    The best thing about that video Krall posted is that it identifies most of the usual causes of misfiring. Not everybody will find that the spark plugs are the cause, in their own car. Some will have to work through more of the usual suspects. But it is always good to remember that (1) misfiring in a Prius sounds horrible, whatever is causing it, but (2) some of the things that cause it aren't horrible to fix.
    #19 ChapmanF, Oct 2, 2021
    badprius likes this.
