Which cylinder is which?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jon Schro, Sep 30, 2021.
  1. Jon Schro
    Jon Schro New Member
    Middletown, Connecticut, USA
    Sorry for the newbie question, but how do I know which cylinder is which?
    I'm getting a misfire in cylinder #2. Is that the second one from the left, or is that the second cylinder in the firing order shown here?
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Second from the left. How many miles, and what year is your car.
    Raytheeagle likes this.
  3. Jon Schro
    Thanks. 2010, 190k miles. P0302 code. Engine knocking. Coolant level is low. I'm worried about a head gasket failure.
    Got it all opened up to access the spark plugs now. I bought a leak down tester on amazon and I'm gonna try to figure out how to run the test on cylinder 2.
    Would appreciate any further tips while I got it opened up. Thanks!
  4. xliderider
    8,140
    3,277
    Honolulu, HI
    Sounds like head gasket failure, usually between cylinder 1 and 2. Perform the leakdown test on all 4 cylinders, not just on cylinder 2.
  5. Mendel Leisk
    41,940
    Visual aid:
    How many miles on the car, and has the intake/egr been cleaned?
    Info in my signature.
    memory and fuzzy1 like this.
  6. Jon Schro
    Is it okay to do a leak down test with the engine cold? I can't really run the engine long enough to warm warm it up.
  7. Mendel Leisk
    41,940
    Don't see why not, but I'm clueless. You're basically trying to see how and where air's escaping, should work with cold engine. The rule I've heard is the cylinder should be at TDC of the compression stroke. Now how you determine it's the compression stroke is a little tricky. And is it critical, or would either TDC (compression or exhaust) give sim results. I defer to:
    He has trouble with the gauges, but gives tips on how to determine compression TDC, and he does ultimately nail the problem, gauge issues aside.
  8. Jon Schro
    So... First I pulled the spark plugs out, and the spark plug from Cylinder #2 (the one misfiring) was black and oily.
    Then, I ran a leakdown test on each cylinder. #1 and #2 were good, but #3 and #4 both leaked around 60%. I listened carefully, and really it seemed like the leaking sound was coming from the same cylinder which was being tested at the time. Nothing from the dipstick hole, no bubbles in the coolant. Am I doing this right? I removed, reattached, and reran the test several times to make sure it had a good seal. I also tried turning the engine down 360 degrees to get back to TDC again just in case I was on the wrong stroke.
    I suppose cylinder #3 and #4 are leaking into each other? (even though the sound seemed to be coming from the cylinder being tested rather than the adjacent cylinder?)
    Any thoughts on what this all means?
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    Black and oily spark plug is from oil fouling, the intake manifold sucks up oil from the PCV valve vented from the lower engine block.
    Maybe you should check your PCV valve while you have some parts off. Since the cylinder leakdown was good, the oil isn't coming from the crankcase side of the rings. The intake manifold is pretty easy to remove, compared to the windshield cowl and coils/plugs.
  10. Jon Schro
    That makes sense, but I already cleaned the intake and replaced the PCV valve. Anything else I should try?
  11. rjparker
    10,574
    6,630
    Anyone in a similar situation needs a cold engine with the cooling system pressurized to 15 psi and then inspect cylinders with an articulating borescope.
    #11 rjparker, Oct 12, 2025
  12. BiomedO1
    4,204
    2,195
    SacTown, Ca
    Zombie thread - 4 years old......
  13. Cheryl A
    Cheryl A Junior Member
  14. Mendel Leisk
    41,940
    What does it matter, info is info?
    Presumably means able to look over it's shoulder. (now I'll have a Donovan song for earworm all day... :rolleyes:)
  15. rjparker
    10,574
    6,630
    Articulating Borescope with ability to move camera from display
    Eric O has demonstrated his on several occasions
