Hybrid Assistant vs. Dr Prius pro.
Discussion in 'Prius v Main Forum' started by skydivetoday, Oct 2, 2021.
  1. skydivetoday
    skydivetoday Junior Member
    25
    Marco Island , FL
    2014 Prius v wagon
    Hello everyone,
    I have 2014 V and bought the Dr. Prius Pro app to test my car and get some information about it.
    Then, I downloaded the Hybrid Assistant app found it to be much more rich in daily driving information about the hybrid car. I find it easy to read and the color coding tells you if something is out of range.
    I wonder if there are other apps that Prius drivers find useful.
  2. vvillovv
    vvillovv Senior Member
    3,614
    1,272
    NY
    I think most will agree that DrPrius is focused more on the traction pack with a few other options available.
    The Hybrid Assistant family of apps Hybrid Reporter and (Tire Assistant TPMS sensor location, tire pressure and temperature) has more options and fancy graphics along with the data.
  3. Mendel Leisk
    38,651
    I’ve got Clarista Bluetooth OBD adapter for Dr Prius; wondering would it work with Hybrid Assistant?
  4. skydivetoday
    25
    Marco Island , FL
    2014 Prius v wagon
    I have Veepeak Mini Bluetooth OBD2 and it has been working for both apps.
  5. vvillovv
    3,614
    1,272
    NY
    Load up the app and see, while your at it grab Hybrid Reporter and Tire Assistant.
    Cheers
  6. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    Yes. Should work fine as long as you are using an Android phone.
  7. Mendel Leisk
    38,651
    Yeah noticed that; major stumbling block...
  8. skydivetoday
    25
    Marco Island , FL
    2014 Prius v wagon
    Only in Android is a major short coming for a very well thought-out product as Hybrid Assistant. Can it not be recompiled for apple?
  9. royrose
    1,389
    949
    Foot of Pikes Peak
    The phone doesn't have to have cell service. You can get a used cheap one, connect to wifi and download the app.
    V Sport Wagon and Mendel Leisk like this.
  10. skydivetoday
    25
    Marco Island , FL
    2014 Prius v wagon
    Well worth the cost of used phone because it wil give you great feed back on how to drive a hybrid.
    As well, it tells you when you are going 50 mph and the engine is only at 1000 rpm.
    It gave me a better understanding of how little brake pads are used.
    V Sport Wagon likes this.
  11. vvillovv
    3,614
    1,272
    NY
    is there such a thing as beater phone? Thanks for the howto, I was thinking on older android ver. (maybe 8 oreo? ) and a pay as you go plan. Can the phones connect to wifi without a sim? I'll have to check the Hybrid Assistant docs for current minimum requirements. DrPrius requires android 4 as a minimum at last reading.
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    I got a refurb galaxy S3 years ago for the Hybrid Assistant/Reporter app. Phone was never put onto a carrier and basically works like a small computer. Still has emergency ability though.
    And...HA is now combined with HR as one app instead of two separate apps.
    royrose and vvillovv like this.
  13. sylvaing
    sylvaing Active Member
    1,028
    424
    Just tried the Veepeak OBDCheck BLE+ adapter in my 2017 Prius Prime with Hybrid Assistant. Can't get the MG/Inverter temperatures at all and the display refresh is very slow compared to the OBDLink LX. I'm returning it and buying a vLinker MC+ to try instead. Still much cheaper than the OBDLink but more expensive than the Veepeak.
  14. TMR-JWAP
    6,193
    5,891
    Columbia, SC
    The Hybrid Assistant web site provides a list of recommended adapters. I bought the OBLink LX and I'm quite happy with it's performance. At the time, a handful of years ago, it was $49 or $59 bucks.
  15. sylvaing
    1,028
    424
    It's about $120 Canadian now. I want to return the LX to the Tesla because that one has a lot of data to show, way more than the Prius. The HA site says the vLinker MC+ is as fast as the LX for about 60% of the cost. I shall see later this week if it works as well.
  16. MattFL
    MattFL Member
    163
    47
    If you're buying a device just to have Android, you can get a tablet instead of a phone and have a larger screen.
  17. sylvaing
    1,028
    424
    Indeed, but I'm part of the 50% of North Americans that do not use an iPhone so I'm fine :D
  18. sylvaing
    1,028
    424
    Got my vLinker MC+ and tried it instead of the OBDLink LX. Same performance for 60% of the price :)
    The following link shows the performance of both as seen by Hybrid Assistant. The OBDLink has finally returned to the Model 3.
  19. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Sounds like your using Forbidden Fruit......................
