Brightest red 2825 LED tail light bulbs?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Galane, Oct 5, 2021.
  1. Galane
    Galane Junior Member
    77
    Idaho
    What red LED bulbs have you used to replace the tiny and rather low brightness 2825 bulbs in the tail lights?
  2. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    If they can be accessed, sylvania makes a Zevo brand super bright 2825 led
    Available autozone or Amazon
  3. dolj
    dolj Senior Member
    7,648
    3,858
    Wellington, New Zealand
    You don't want the tail lights to be brighter than the factory incandescent lamps though and they should be a good factor less bright than the brake lights. It is very jarring following a car that has its taillights as bright as brake lights.
    Mendel Leisk and Another like this.
  4. Galane
    77
    Idaho
    I got these for the tail lamps.
  5. Galane
    77
    Idaho
    These for the backup lights. Very bright, lights it up real good for the backup camera.
  6. Another
    1,802
    511
    Naples, Florida
    I think the point made above about not having too bright tail lights is a good point as it’s distracting to drivers behind you and makes the brake lights less obvious.
    The bright backup lights however is a good idea.
