Sound deadening/insulation installed
Discussion in 'Gen 2 Prius Accessories & Modifications' started by OC63RAG, Oct 8, 2021.
  1. OC63RAG
    OC63RAG Member
    94
    42
    I'm sure this has been covered but I wanted to share my experience with this. I went from a Lexus LS sedan to my Prius and one of the first things I noticed when driving was the amount of road noise and the perceived lack of solidness. I know this is typical of most (all?) compact cars these days but it was really noticeable to me.
    I bought some Frost King adhesive insulation at Home Depot for $26 (12" x 15') and applied it to the four doors and rear hatch. Huge difference in the sound and feel. Even when you close the doors they seem more solid and close with a thunk.
    I'd highly recommend this if anyone has been considering it. Cheap and easy and provides a big improvement.
  2. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    There was a thread a few months ago about this issue but my recollection was the material used was a rubberized product from Amazon that is thinner and more expensive. This sounds like an interesting thing to try. Did you take any photos or have any problems with removing or replacing panels?
    OC63RAG likes this.
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Every fridge door gasket set I've seen is gray.
    +1 photos needed
  4. OC63RAG
    OC63RAG Member
    94
    42
    Sorry, no pics but the panels were super easy to remove/install. Two screws and some clips. I watched a bunch of videos and researched Dynamat installation. One of the posts I found was from an acoustic engineer who said you only need 30% coverage to get sufficient dampening.
    Based on the construction of the Prius doors, I ended putting large panels of insulation inside the holes and on the outside door walls. For the inner sections, I put small pieces wherever there was space (especially around the speakers).
    $26 and about two hours was well worth it.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    From a Lexus to a G2 oh the humanity :cry:.
    The front doors respond greatly to any insulation. I had a new stereo and front speakers installed at Best Buy and they left the clear plastic cover off the inside of the door. It just seals all the door mechanicals and now the door makes a loud hollow metal boink noise when you shut. Just that little cellophane missing off the inside of the door caused a lot of noise.
    I put a lot of eBay peel and stick in the hatch floor and spare tire tub that really helped.
    kenoarto likes this.
  6. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    I highly recommend Damplifier Pro from Second Skin Audio. I had a whole thread on doing my 2007 but the Photobucket links have all failed.
  7. Another
    1,802
    511
    Naples, Florida
    What exactly did you use on the hatch floor and tire tub? That seems a simple solution to try. Would like to match what you suggested not try to reinvent it.
  8. Another
    1,802
    511
    Naples, Florida
    I guess I’ll look at this
    Manufacturer ‎Vibro Solution
    Brand ‎Vibro Solution
    Item Weight ‎4.69 pounds
    Product Dimensions ‎23.5 x 19.5 x 0.5 inches
    Is Discontinued By Manufacturer ‎No
    Manufacturer Part Number ‎VS-SE1200
    Additional Information
    ASIN B07J4JFJLJ
  9. don_chuwish
    816
    182
    Southern Oregon
    Looks like they have some good options!
  10. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
    affiliate linking?
    $113 vs $26? Quite the price diff, I'm inclined to go with $26.
    #10 alftoy, Oct 21, 2021
    OC63RAG likes this.
  11. Another
    1,802
    511
    Naples, Florida
    If you’re implying that I get some sort of kickback, you’re wrong.
  12. ColoradoCrow
    ColoradoCrow Active Member
    968
    392
    Leawood, KS
    I
    I installed 2 complete boxes of Kilmat that I ordered off of Amazon. $120 total. I did the entire roof, doors, interior floor and trunk in my wifes car. It took about 8 hours to do it over a couple of weekends. It was a lot of work but well worth it. My prius is loud in comparison to hers.
    it was the .80 thickness FYI. But I LOVE the simplicity and low cost version that you did. I might start with that with mine.
    audiodave likes this.
