2006 wet floorboards after ac repair
Discussion in 'Newbie Forum' started by lllorie, Sep 25, 2021.
  1. lllorie
    lllorie New Member
    Totally new to this, or any forum. situation CRITICAL - had compressor, receiver dryer, & drive belt replaced at Toyota dealer. now both floorboards are wet, dried them once, wet again.
    i read the posts about checking the tube under carpet. is there a tube on both sides?
    here's the critical part, I'm in Texas, i need to go to Tennessee. my dad is in bad shape in the hospital. so i need to find out if it will damage anything else if i drive on up to Tennessee, with 'iffy' ac repair/problems.
    i can try to do a quick check on tube(s), maybe gently run a 'fish-tape' up in it, but really need to leave out for Tennessee, like yesterday. Thanks, in advance
  2. JohnnyPR
    JohnnyPR Junior Member
    75
    Hinesville, GA
    Welcome! Have you fixed the leaking issue?
