Charger holder?
Discussion in 'Prime Plug-in Charging' started by PiPLosAngeles, Oct 16, 2021.
  1. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Won't reach. It just barely has enough cord to be able to mount it next to the outlet if there was a spot. I'm seriously considering cutting that infernal CATV cable and getting rid of it and that poly pipe. I don't have cable TV or internet and don't plan on it.
  2. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    I mean the height of the outlet....but doesnt matter, it is grandfathered lol
    One screw to brick, cement, epoxy or liquid nails that brick to your brick where ever u want it. done deal.
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    So you'll be removing the cord when inclement weather approaches?
    If so, why even mount it to the wall:whistle:?
    One less hole in the wall(y).
  4. bisco
    52,390
    ocd :p
  5. PiPLosAngeles
    1,551
    724
    No. It's not exposed to the weather where it is. The right side could occasionally get some small spray if there's blowing rain, but nothing from overhead.
  6. PiPLosAngeles
    1,551
    724
    California Electrical Code doesn't have any height requirement that I can find.
    #26 PiPLosAngeles, Oct 16, 2021
  7. Sgt Bill
    Sgt Bill Member
    42
    35
    St.Louis Mo.
    Just finished moving my charging station.Got tired of having to back into my garage to charge our Prime so I moved the station to the side wall.I had previously debadged the car so I had all the badges.I have attached photos what do you think.(yes I am retired and have lots of time on my hands to do these things)
  8. Inspectorman
    Inspectorman Junior Member
    24
    2018 Prius Prime
    The Prime charger has two holes - both on one end. Just get a drill bit designed for drilling into the brick and you will be good.
  9. MTN
    MTN Active Member
    306
    276
    SB, CA
    Can't you just zip tie it to the PVC pipes?
