Tags:
  1. Henrik Helmers
    Henrik Helmers Active Member
    100
    148
    Norway
    2020 Prius PHV
    Winter is here, and so I like to do things like preheating the car. But it feels weak. At almost 30.000km I'm thinking ...maybe I used up the magic? I used plenty of heat last winter—and plenty of cold this summer.
    1. How long is the AC coolant supposed to last before being replaced?
    2. The temperature is about 10°C in my garage. How long does the car need to preheat to raise cabin temperature to 20°C?
    I talked to my Toyota dealer and asked them for an appointment to replace the coolant, but then the service person wanted to inspect the car, thinking maybe something was wrong. I didn't think there was anything wrong, but now I am unsure?
  2. Salamander_King
    Salamander_King Senior Member
    10,963
    8,839
    New England
    Humm, so you are saying it worked before but now it doesn't? With my experience on the previous two PP models, 2017 and 2020, the heat pump was never efficient to heat the cabin in "cold temperature". Here when I say "cold" it is usually below 32°F (0°C). I don't use heat unless the ambient temp gets to the low 30s (single-digit °C) or lower. As you probably know already, at below 14F (-10°C) the heat pump does not work at all. I have tried using preheating several times with my 2017 PP, but it never worked to my satisfaction. The cabin was never warm to the AC set temp and it used the traction battery charge reducing the EV range. So, I stopped using the function altogether. Instead, during winter, I just started a car in HV mode as soon as I get in the car in the morning and used the heat from the engine. I didn't drive the 2020 PP for commuting, so I never needed to do that, but for my 2021 PP, if I do regular morning commuting this winter, I will do the same or maybe use CHG mode on my morning commuting if the price of gas comes down.
  3. Henrik Helmers
    100
    148
    Norway
    2020 Prius PHV
    I think it used to be faster. That may of course be wishful thinking. But it also cooled slowly at the end of summer, again the long delay before delivering initial heat or cold.
    Salamander_King likes this.
  4. Salamander_King
    10,963
    8,839
    New England
    The coolant replacement is scheduled to be at 100K miles (~160K meters) in the US. It is hard to believe it needs to be replaced so early. As I said, I don't use preconditioning, so I don't know what is the normal change in the performance over a year or two. I also don't use HVAC much 9 months out of a year, except when my wife is riding the car with me, so I don't know how that performance changes over time either. At least for my 2017 PP which is the longest owned PP, I did not feel any degradation in HVAC capability over the 2.5 years I have owned.
  5. Henrik Helmers
    100
    148
    Norway
    2020 Prius PHV
    That's good information. I'll update this post once the mechanics have looked at the car and told me to stop complaining. :)
  6. vvillovv
    vvillovv Senior Member
    3,528
    1,241
    NY
    That's a common issue for me "losing the magic". It seems that way for most anything acquired new these days, again for me anyways. phones, TV's, computers, batteries, etc... If I'm excited about a new model, I find the "magic" usually dies a slow death within a few weeks as the new acquisition begins to fade into the background of life as time marches on. ;)
    adding heat to the cabin using Climate Control automation when the ICE is not running, never impressed me either. I use a regular safety switched space heater before leaving on a trip, if I really want heat in the cabin when it starts getting really cold. as always YMMV
    #6 vvillovv, Oct 19, 2021
  7. BiomedO1
    1,315
    719
    SacTown, Ca
    Have the Toyota dealer check your A/C system; since your running a heat pump. You may have a slow seepage leak in the system and I believe there is a TSB for that. The leak is at the O-rings that connect to the condenser, in front of your radiator. Look at those connectors for an oily dirty residue around the connector and bolt. If your levels are low; the cabin won't heat or cool as well as it should. Of course you know, as it get colder, the heat pump becomes less efficient and your engine will fire-up to heat the cabin.
    Hope this helps...
    vvillovv likes this.
  8. vvillovv
    3,528
    1,241
    NY
    I don't have techstream so I can't see the actual TSB issued by Toyota.
    A ton of hits from search though.
    edit Thanks @BiomedO1
    #8 vvillovv, Oct 19, 2021
  9. Salamander_King
    10,963
    8,839
    New England
    BTW, when I said replace the coolant, I meant the engine coolant of the radiator. I am not aware of any refrigerant service mentioned in the manual. Still hard to believe it needs to be replaced or filled, but @BiomedO1 commented a good point if it is related to the refrigerant leak, then it would explain the loss of heating or cooling efficiency.
    fuzzy1 likes this.
  10. Henrik Helmers
    100
    148
    Norway
    2020 Prius PHV
    Ah, I see. And many thanks for that PDF, I will print and bring it to my dealer, maybe it will help them investigate. (y)
  11. Henrik Helmers
    100
    148
    Norway
    2020 Prius PHV
    I had my car inspected and tested under warranty. I am unconvinced of their testing method, as despite me trying to explain multiple times that the heat pump was used for heating as well as cooling, they only tested and confirmed cooling (in the winter no less). They also did an inspection and checked pressures, all was fine.
    What I also noticed is that heat does work well at around 10°C outside temperature, but when it reaches 0°C it takes ages (15 minutes+) to start generating heat. Heating performance (and a heated steering wheel) is something I will keep an eye out for when purchasing my next vehicle. For now I'm just wearing my winter coat :D.
  12. vvillovv
    3,528
    1,241
    NY
    The Prime will blink the Temp gauge on the dash for 5 to 10 seconds when first put into Ready mode, at either 2 or 3 degrees C, and there are major changes to the way the car behaves below those temps. We all watch as temps start to fall in the fall, which big changes are going to get the most post counts. So far this year it's The ICE starts up when it's Cold even in EV mode.
    Heat pump NOT providing cabin heat in temps below 37 F / 2 or 3 C, is NORMAL. again as always YMMV.
    Pre Conditioning adds other values to cold start trips, besides the side effect of sometimes being able to add heat to the cabin.
    #12 vvillovv, Nov 11, 2021
  13. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    This all sounds normal to me. Heat pumps are pretty inefficient below freezing, and the colder it is the less efficient they are. That's why the ICE starts up when the temp drops in order to make heat. Bottom line anyway is that you're wasting energy trying to make heat with a heat pump in the cold, might as well just run the ICE.
  14. Salamander_King
    10,963
    8,839
    New England
    As suggested, my experience with PP is that the heat pump in winter is useless. Especially on shorter than 30 min morning commute. I could never get the cabin temperature to get more than 5F higher than the initial temp. When I was commuting daily, I almost always started the car in HV mode as soon as I get in the car. From my experiments, I have learned that the HV and CHG mode efficiency is very close, so I plan to use CHG mode in the morning commute to get constant heat and save the EV mode for the afternoon.
  15. Henrik Helmers
    100
    148
    Norway
    2020 Prius PHV
    I use a heat pump to heat my home, I believe this is pretty common in the nordics. At -7°C it as an efficiency coefficient of about 5, and for -25°C the coefficient is more than 3.
    I understand that there are constraints when making car. The heat pump in mine does work, it just takes a bit too long to heat up than I'd like. Or maybe I'm just grumpy over the lack of the heated steering wheel option :p.
    pghyndman likes this.
  16. vvillovv
    3,528
    1,241
    NY
    grumpy - heh I've been wearing summer riding gloves the last few nights, even though I don't really need them yet.
    dress appropriately (bundle up), open window(s) slightly to remove window foggy.
  17. pghyndman
    pghyndman Active Member
    498
    464
    CT shoreline
    Amen! While we don't have such bone-chilling temps here, the heated steering wheel AND heated seats do make it a lot more bearable in our Southern New England winter weather.
