What every newb should know
Discussion in 'Newbie Forum' started by richard schumacher, Jun 8, 2008.
  1. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Actually, now that I think of it, it's been so long since I used the actual USB charging port OR the USB data port that I don't recall how well they performed -- just that I don't think I had a problem. What I've used for a long time is a USB hub plugged into an adapter in the 12V accessory plug.
    Prodigyplace likes this.
  2. Emanuel Barros
    Emanuel Barros New Member
    portugal
    a. MAY TAKE LONGER TO BRAKE THAN YOU EXPECT! "Slippery" includes water, snow, ice, sand, gravel, oil, manhole covers, pavement stripes, speed bumps, and broken or pebbly pavement. Find a slippery empty parking lot and practice some panic stops before you ever have to make one.​
    Can you elaborate this better?
    Why? Longer to brake because is a Slippery surface like any other car with the same tires.
    Or Longer because has not so good ESP/ABS?
    I was planning to buy a 2nd gen prius.
    Thanks
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    The traction control automatically enabled before Gen 4 can extend braking distances in scenarios mentioned above. The Gen 4 has a switch to disable traction control if needed. In panic situations it also amplifies the braking to help stop quicker. This is only for Gen 4 though.
    Emanuel Barros likes this.
  4. Emanuel Barros
    portugal
    Thanks for the fast response!
    So.. in your opinion is just a bad esp/abs compared to other regular car.
    Because gen4 is good.
  5. Prodigyplace
    11,696
    11,317
    Central Virginia
    I have never yet had to turn it off in my Gen 4 through 3 winters with snow.
    Emanuel Barros and parnami like this.
  6. Purrius
    Purrius Junior Member
    58
    Northeastern US
    Thank you so much for this post! It really saved my tail today!
    floydr likes this.
  7. PRIUS FOR EVERYONE hum...
    Mesquite, Nevada
    Top ½ fills just as easy as the bottom ½
  8. goatemail
    goatemail New Member
    Brooklyn NY
    thanks for this thread! very helpful
  9. Gavin Sun
    Gavin Sun Junior Member
    China
    Great place for Pruis,thanks.
  10. jeremy rutman
    jeremy rutman Junior Member
    moore, oklahoma
    2015 Prius v wagon
    Concerning fuel economy and the 'B' gear;
    a. is it ok to engage 'B' anytime I would otherwise brake (e.g highway off ramp at 60mph)
    b. I can't recall the exact situation but iirc the eco diagram of where energy is going, doesn't quite line up with my understanding of what 'B' does, namely regen braking
  11. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    B is for engine braking, typically on descents of 600 feet or more. In those circumstances, your HV battery will fill and you will only have friction brakes. By engaging B at the top of the hill, engine braking will make it take longer to fill the battery, making a safer descent.
    (If you had a Prius Prime, the rules change)
    jerrymildred likes this.
  12. vvillovv
    vvillovv Senior Member
    3,536
    1,246
    NY
    Hi Jere I've been told that B mode can overspin the ICE (internal combustion engine) at high speeds and I've noticed that with the Prime as well in HV mode, when the engine is running. So, I'd suggest you only use B mode at speeds where you feel comfortable with the RPM's that the Engine is revving up to, when engaging B.
    The reason the rules changes with the Prime is in EV mode the Engine rarely if ever (depending on how one drives it) turns on and B mode can be engaged at any speed when the Engine is not running. Also due in part to the changes made to the way MG1 and MG2 work in the Prime as compared to the regular Prius.
  13. TheNomadicAspie
    TheNomadicAspie New Member
    Las Vegas
    I recently jump started another car with my Prius and now I have the problem light and a bunch of check engine lights on. Any idea what I should do?
    The codes are p0420 (cat efficiency below threshold), c0200 (right front wheel speed sensor signal malfunction, c0205 (left front wheel speed sensor malfunction), c1241 (low battery positive voltage or abnormally high battery positive voltage), c1242 (open circuit in ig2 circuit), and c1300 (malfunction in ecu).
  14. vvillovv
    3,536
    1,246
    NY
    That's the easy one and first one I'd check.
    Not a good idea to use the Prius 12 volt to jump another vehicle, as you found out..Try using PriusChat search box for more info on jumping another car with your prius.
  15. ChapmanF
    15,111
    Getting back to a post from October, B mode won't overrev the engine; the ECUs know exactly what the comfortable top RPM for the engine is, and will go right up to that if the descent is steep enough, but not a hair over.
    Beyond that point it just won't be giving you any additional engine braking, so you will notice the car picking up speed, and will have to snub it with the friction brakes.
  16. gogreener
    gogreener New Member
    nevada
    2018 Prius
    yes, thankful for this thread. newbies unite!
  17. Eric Z.
    Eric Z. New Member
    Milwaukee, WI
    2014 Prius v wagon
    When I compare my MPG using the odometer and number of gallons, it is almost always a little lower than the car's calculation. I assume this is because the car often stops displaying a current MPG when idling but not moving (when it technically should say zero).
    I had not known about the internal bladder in the tank. This would complicate things.
  18. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The North American Gen 2 Prius has a bladder. The Prius v does not.
  19. UpNrth
    UpNrth New Member
    United States
    2015 Prius c
    Whew.. here I thought I was just buying a new car.. appreciate all the info
  20. ebee
    ebee New Member
    Looks like I've gotten lucky a couple of times... Barely coasting into a gas station in the middle of Nowhere, KY, and jumping another car, both without lasting damage. I do think I'll try to avoid pressing my luck in the future if I can help it. Thank you for this list!
