How much Water is too much?
Discussion in 'Prime Main Forum (2017-2022)' started by hallebenjamin, Oct 22, 2021.
  1. hallebenjamin
    hallebenjamin New Member
    San Antonio
    I have noticed a drip from my undercarriage. Clear and cool. Im guessing it is water from A/C. Coolant levels are full and not falling faster than normal.
    Issue is it seems to be a lot of water. It is happening every time I drive and it will continue to drip for long periods of time, even after the car is off. It has been hot where I live, 80-90 degrees with at least 30-50% humidity.
    Is this normal? How much water is too much or sign of a bigger issue?
  2. schja01
    schja01 One of very few in Chicagoland
    1,732
    1,157
    Chicagoland
    2018 Prius
    Probably normal. Try running car for an hour with a/c off and see if the dripping stops.
  3. BiomedO1
    1,320
    722
    SacTown, Ca
    The drip is normal; condensation coming off of your evaporator. You would have a bigger problem; if it wasn't dripping. That would mean that your drain tube is clogged and water would be pooling in your HVAC system. The dark, cool environment is perfect breeding ground for mold formation.
    FWIW: I turn-off my A/C system 10-15 minutes before my destination - giving it a chance to blow-out/dry-out; thereby reducing the chances of mold formation. I realize you can't do that all the time, because it's 90+ out there; but when you can do it - you probably should.
    Hope this helps.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    And if you are not in the habit of running the AC in "recirculate" mode, try doing that.
    It should cut down on the amount of condensation......maybe by a LOT.
  5. vvillovv
    vvillovv Senior Member
    3,536
    1,245
    NY
  6. ChapmanF
    15,097
    30-50% sounds almost arid, but what I am finding on Google suggests San Antonio averages well above that, getting a lot of air from the Gulf. Plenty of water there for the A/C to be squeezing out of the air.
    hallebenjamin likes this.
  7. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Sounds very normal. Especially if it's not in recirc mode. But I keep mine in recirc and always seem to have a small lake under the car.
    In fact, "too much water" would be an impossibility. Not enough water might indicate a problem though. The more the system can reduce the moisture in your cabin air, the better it's working.
  8. hallebenjamin
    San Antonio
    Thank you all for the replies, I feel much better now.
  9. PT Guy
    PT Guy Senior Member
    1,083
    708
    Washington, the state
    "Im guessing it is water from A/C. Coolant levels are full and not falling faster than normal."
    If it is clean, clear water, it is condensation of the humidity in the cabin air. There is no colorless water in the car's systems. You'll see the pink dye in the coolant reservoirs under the hood. If it was brake fluid your brakes would have already failed. Brake fluid feels odd when rubbed between the finger tips. Transmission fluid is oil dyed red. Engine oil is, well, oily, and usually dirty. That covers the fluids in a Prime. How do you tell the color?...soak some up in a white paper towel.
