Gen 3 Temp Light Came On / Heater Blowing Cold Air
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Levi Gonzalez, Oct 26, 2021.
  1. Levi Gonzalez
    Levi Gonzalez Junior Member
    59
    Jonesboro AR
    So the temp light came on last night on my 2013. Never had the Coolant replaced since I owned it personally (140k). But the levels looks good.
    Last night when the light came on, I turned on the heater to max and it blowed out hot air for a while then the light immediately went away (it was a cold night).
    However a few minutes later the heater (even though temp was on max) started blowing out cool-ish air. then it would go back to heat.
    Any information on what it could be?
  2. JC91006
    JC91006 Senior Member
    16,468
    8,383
    You should read the codes to see what the car has stored. It could be anything, but temperature warnings would point you to coolant or waterpump/thermostat
  3. Levi Gonzalez
    59
    Jonesboro AR
    I'll check that. Could it be a coolant issue even though coolant is still in there. and hasn't recently been replaced (no bubbles probably)?
  4. JC91006
    16,468
    8,383
    If it's a temperature light it could be anything that's related to the coolant loops. In the Gen2 cars, the inverter coolant pump goes out every 100k miles or so. So you may be having the same issue. You'll need to read the codes to really know the issue, it'll help pinpoint the problem.
  5. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Probably air in heater core
  6. AzusaPrius
    AzusaPrius Senior Member
    1,664
    768
    No check engine light was mentioned, he can still look for hidden pending codes I guess.
    Check to see if you have the auto button on and turn it off also keep the circulation button on.
    Do you hear any water boiling sounds in the cabin?
  7. Levi Gonzalez
    59
    Jonesboro AR
    P148F.
    I ended up putting the coolant to the max line, and so far it hasn't overheated or giving me any codes yet....
    even though it wasn't under the low-line previously, maybe it just needed to be filled to the brim?
  8. JC91006
    16,468
    8,383
    Losing coolant (if that's the case here) is not a good sign for Gen3 Prius cars. Pay close attention to that coolant level and maybe as a preventative measure, clean out your EGR circuit and Intake Manifold areas. These cars are notorious for higher mileage head gasket failures, and it all starts from losing coolant.
    Levi Gonzalez and m.wynn like this.
  9. ChapmanF
    15,055
    That's the code for the engine's electric water pump spinning too fast.
    Wait, you're thinking, why would the water pump spinning too fast be a problem?
    Because it probably means the impeller inside the pump has separated into a couple of pieces, and it is spinning too fast because it doesn't pump much water that way.
    Levi Gonzalez likes this.
  10. Levi Gonzalez
    59
    Jonesboro AR
    Good to know. however this is the first time I put coolant in the car in 40k miles so hopefully it was just simply low and not a bigger issue. we shall see!
  11. Levi Gonzalez
    59
    Jonesboro AR
    Are you sure? From what I read that's the code for low coolant.
  12. ChapmanF
    15,055
    [Generic comment on the reliability of different places to "read" things goes here.]
    I have a 2010, which was before they added the code, so it is not covered in my repair manual. It was apparently added in the 2011 edition.
    The car's repair manual is one of the better places to "read" things. They usually turn out to be true if you read them there.
    On the other hand, I should confess that I didn't look it up in a 2011 manual myself; I have just taken Elektroingenieur's word for it.
    That wasn't my first or the last time taking Elektroingenieur's word for something. It's theoretically possible that something you've "read" somewhere else is more reliable. You just have to ask yourself: do you feel lucky?
  13. JC91006
    16,468
    8,383
    At 140k miles, you're due for the water pump and coolant change. Do them and you should be back on the road without issues (coolant related)
  14. ChapmanF
    15,055
    There is, of course, one way that code (which is for water pump overrevving) could be connected to low coolant.
    If your coolant gets so low that the water pump isn't in it, naturally the pump will overrev.
    That would be low coolant all right. The pump is pretty low on the engine.
