JBL BOOMBOX as a wireless subwoofer for prius prime
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Apnea, Nov 14, 2019.
  1. Apnea
    Apnea New Member
    Los Angeles
    Had the nice idea that maybe instead of having to install actual wiring into a prius to set up a subwoofer system, maybe this jbl boombox that is supposably "the loudest " portable speaker on the market right now might be able to connect to the prius bluetooth ? Anyone Know?
    TGrracie likes this.
  2. mrdata71
    mrdata71 Member
    37
    US
    2026 Prius Plug-in
    XSE Premium
    That sounds like an awesome idea if it works, but would you wire your phone to the cars integrated USB up front to do phone calls?
  3. 1x1
    1x1 Member
    147
    45
    The Aiwa Exos is also pretty good
  4. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    I am not sure you can establish a bluetooth connection from the car to the speaker, as the car only receives connections as does the speaker.
  5. usbusi
    usbusi New Member
    Costa Mesa, CA, USA
    It depends if the boombox model has output port(s) or not. If so, bluetooth to the boombox (not to the Prius) from your phone, and audio cable (output) from the boombox to the Prius aux input port.
    (Unfortunately many portable speakers don't have output ports. And many of the new JBLs apparently couple only wirelessly.)
    The partybox 1000 has output ports, but is $1,200. There might be other brands with output ports.
    This would be a good new feature for the jbl stereo upgraded stereo systems in the Prius, the True Wireless coupling feature, to couple to a jbl boombox.
    The good news? You can charge boom boxes at least with a cigarette lighter inverter. Mine is 300 watts.
    #5 usbusi, Nov 6, 2021
