My Prius dead again, with techstream this time.
Discussion in 'Prius v Main Forum' started by gromittoo, Oct 16, 2021.
  1. Tim Jones
    Tim Jones Senior Member
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    I've never had a Chrysler.
    But plenty of fords, chevys, and a 280 z.
    NO blown headgaskets. Five Goldwings.... NO blown headgaskets.
  2. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    I am going to buy the
    Ruien Universal 350ml Oil Catch Can Tank 0046 Aluminum Polish Baffled Reservoir in black on Amazon.
    The reviews say that the included hoses are garbage, use your own. The last of the photos showi the OCC mounted behind the left headlight also shows clear hoses with reinforcements.
    These hoses remind me of the hose that is attached to the sprayer on a kitchen sink. A clear hose has the advantage of showing if the OCC has overflowed. Where would one find oil resistant hose like that?
  3. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    Same setup I have. Hoses are a joke.
    My hoses come from the back.
    Oddball size on the catch can as I had to wrap electrical tape around the cc tube for proper fit.
    Plus the o ring for the cap doesn't last very long.
    It will never overflow if you check it once or twice a month.
    #223 Tim Jones, Nov 13, 2021
  4. Mendel Leisk
    41,163
    Look for fuel hose, more'n likely 3/8" ID. Spec SAE30R7 (or ...R6) is good. You can buy it by the foot at most any automotive specialty store, for a buck or two per.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,426
    2,393
    Taylors, SC
    NAPA is a good source for 3/8 inch gas line hose. They still sell it by the foot, instead of packaged specific lengths.
    If you want clear like the supplied hoses, the stuff that looks the same sold in the plumbing department at Home Depot or Lowe's is much stiffer and stronger, It does not collapse when you squeeze it between your fingers,
  6. Air_Boss
    Air_Boss Senior Member
    4,177
    1,171
    New Yawk
    1996 Grand Caravan V6 blew its rear bank HG externally at 35,000 miles… Bars Leaks held it until it was stolen at 125,000+ miles.
  7. gromittoo
    719
    288
    philadelphia
    2013 Prius v wagon
    OK, I got my Oil Catch Can today. Amazon ID: B06XJTV45H
    I have to buy hoses, but before that, I need to figure where to put it, and How to mount it.
    I like the location behind the left headlight except:
    First Problem: the mounting holes on the can are not in a good place. One photo shows a custom plastic holder (I found a scrap of 1/8 inch thick Teflon I might be able to use). The Other uses a metal holder for the same OCC. Any idea who made that holder?
    Second problem: I leave my headlights on all the time when I drive. I go through a lot of bulbs, and I keep spares in the foam tray in the back. This location for the OCC means the can must be removed to change the Left side bulb. If the plastic holder allows me to lift the oil can out of the holder without tools, that would work great:)
    OTHER LOCATION:
    I like the location on top of the engine mount, but there is nothing to attach the can to.
    Any Thoughts?
    #227 gromittoo, Nov 22, 2021
  8. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    I don't have mine mounted. It just hangs there. WorKS perfect. I'll send a pic later.
    It's rite by the headlight. Just swings back. Been there for 75,000 miles.
  9. gromittoo
    719
    288
    philadelphia
    2013 Prius v wagon
    No rattling?
  10. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    The second pictured mount you posted is just a large aluminum L stock that has one side of the L cut off. The other side of the L has been bent away to mount the catch can.
    The location near the engine coolant reservoir on the top is the location I relocated my OCC to recently. There is a bolt holding a bracket that holds the two aluminum refrigerant lines for the AC. I fashioned a mount using an L bracket and some 1/8 inch L shaped aluminum stock I had and put it under the mentioned bolt.
    I drilled a hole in the L angle aluminum and secure the OCC mount to it with a ziptie. When the hex cap screws on the OCC mount are snugged tight, the OCC is firmly mounted and will not come loose. 20211113_191543.jpeg 20211008_165122_kindlephoto-575030303.jpeg 20211008_165122.jpeg 20211008_161556.jpeg 20211008_164034.jpeg 20211008_154016.jpeg
    #230 xliderider, Nov 22, 2021
    gromittoo and Georgina Rudkus like this.
  11. Georgina Rudkus
    3,426
    2,393
    Taylors, SC
    It wouldn't be hard to make a bracket from an aluminum plate and other pieces of aluminum bar to make a bracket secured to that large stud sticking up from the engine mounting stud. Another flange nut could easily hold it in place without disturbing the original nut.
    I'd, however avoid any contact with the thin aluminum AC line as it could damage it.
  12. xliderider
    8,140
    3,274
    Honolulu, HI
    I used AN type fittings for my installation. In particular, I used these two types to relocate my PCV valve to the OCC and to make a 180 degree change of direction to the OCC location. The AN6 to M16x1.5 fitting screws right into the PCV valve location or the catch can,they are both threaded the same, that's why you can screw the PCV valve directly into the OCC.
    In addition I swapped the inlet and outlet from the indicated ports that the manufacturer uses on the catch can. The reason for doing this was explained elsewhere. I also put in extra fine mesh stainless steel to greatly increase the surface area in the catch can to condense more oil vapor/mist out of the flow going through the catch can.
    I also put fiberglass heat shield around the OCC hoses that pass between the engine block and intake manifold to keep temps lower so that theoretically it is easier for the oil vapor to condense on the surfaces in the OCC.
    #232 xliderider, Nov 22, 2021
  13. Georgina Rudkus
    3,426
    2,393
    Taylors, SC
    The only thing I'd would to ditch the original mounting bracket on the can and hold it in place to the inside the "v" of the vertically positioned aluminum angle with a large stainless steel worm drive hose clamp. That would allow easy removal for emptying with either a 5/16 inch nut driver or a flat blade screwdriver.
  14. xliderider
    8,140
    3,274
    Honolulu, HI
    Here is the stainless mesh I put in the OCC. I cut 3 inch wide strips of the mesh, rolled it up into cylinders and crimped the ends of one side of the cylinder and folded it over twice. There are at least three or more layers of the mesh in the large cylinder. The smaller cylinder was made by cutting the mesh into a 3 inch wide strip, then cutting that strip in half, so about 6 inches long. Then I secured them further with some wire I had. The small cylinder of mesh is now the inlet, and the large side is now the outlet with stainless steel potscrubber in both the mesh funnel and the OCC outlet screw in canister. Screenshot_20211101-110755_Amazon%20Shopping.jpeg 20211113_084324.jpeg 20211113_084401.jpeg 20211115_104812.jpeg
  15. Georgina Rudkus
    3,426
    2,393
    Taylors, SC
    Easier than aluminum fittings would be this multi-curve 3/8 inch gas line that can be cut to get the specific elbow bend that you need.
    For Mendel: Sidewinder 3/8" Molded Curved Fuel Line Rubber Hose Elbow Universal 45 90 135 180
    xliderider likes this.
  16. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
  17. xliderider
    8,140
    3,274
    Honolulu, HI
    Looks like it would rattle against the inverter or the frame above the headlight.
    Also, why is one hose clamped and the other hose not clamped?
  18. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    Never has rattled in 3 years and 85,000 miles
    Hose without clamp was super hard to push on........ didn't need a clamp.
    There is a clip on the can that rests on the front of the grill.
  19. xliderider
    8,140
    3,274
    Honolulu, HI
    Saw that early on, I guess on hindsight it would be a good way to go. You'd still need a few barb connectors to join everything together.
  20. Georgina Rudkus
    3,426
    2,393
    Taylors, SC
    Here's a good silicone hose that will do 1-1/2 inch radius bends.
    For Mendel: HPS Performance 3/8" ID Blue high Temp Reinforced Silicone Heater Hose 10 feet roll, Max Working Pressure 80 psi, Max Temperature Rating: 350F, Bend...
