Headlight dashboard icon not working?
Discussion in 'Gen 2 Prius Main Forum' started by AJP, Jan 31, 2013.
  1. AJP
    AJP Member
    160
    Central Pennsylvania
    Until about a week ago, when I turned my headlights on, the icon (light bulb) appeared on the dash. Out of the blue, it doesn't. Any clue why?
    (High beam icon still appears).
  2. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    This is not as straight forward as it sounds.
    The body ECU controls the lights it also tells the combination meter where the warning light is that the lights are on but it does this via computer data lines.
    So the likely problem is the combination meter "probably a bad solder joint" but could just as well be a problem in the body ECU.
    You might reasonably have expected this to be a simple wiring problem but having looked at the circuit diagram it is not. The best advise I can give is to live with it for the high cost of any repair.
    John (Britprius)
  3. techntrek
    techntrek Member
    263
    84
    MD
    Or the LED in the dash has gone bad, but that is unlikely.
  4. Britprius
    5,194
    1,922
    The LED is part of the combination meter according to the wiring diagram, but a faulty LED is possible.
  5. AJP
    AJP Member
    160
    At the risk of sounding very ignorant, is there any chance that them doing to repair for the extension shaft recall about two weeks ago would have affected it?
  6. Ahsan Baig
    Ahsan Baig New Member
    Pakistan
    Same problem is with me. But it blinks sometimes. And remains off most of the times.
