charge point chrager top clip broken off and wont charge while works fine on tesla?
Discussion in 'Prime Main Forum (2017-2022)' started by ltlurker, Nov 27, 2021.
  1. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    noticed that in a shopping center that i visit, all the clips are broken off on the charger plugs for charge point and it will no longer charge my prime. However all the tesla and volts are charging fine. my car used to charge fine when the clips weren't broken. wondering what about that clip that makes charging work on prime while not required on other cars?
    you can see the charger shape here with the clip visible right above that plug itself. that part is broken for all the chargers near me.
    https://cdn-cosmos.bluesoft.com.br/products/852941006067
  2. john1701a
    john1701a Prius Guru
    12,821
    5,305
    58
    Manually lift the portion remaining to make charging begin.
    I had to do that for nearly a year at the grocery store. 2 of the 4 stations their had broken clips.
  3. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    can you explain more? which part do i need to lift?
  4. bisco
    52,351
    if the clip is broken, the part you press down with your thumb should still work, unless it is all broken.
    prius requires a handshake, and the thumb clip lever provides that. it opens a circuit while you're plugging in, then closes it when you let your thumb off the lever.
    i thought all plug ins were the same, but i guess not.
    mine broke on my home L2, so i had to move the wires to a switch. i turn it on after i plug in, and off before i remove it.
    if i wait too long to turn it on after plugging in, it won't start charging. i have to unplug and repeat the process. it is an interesting design.
  5. john1701a
    12,821
    5,305
    58
    It's tiny portion remaining. A tiny pocket knife might be needed to get a grip, since what's there is likely flush with the handle.
  6. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    where is the wire? i was looking at a good charge point clip and don't notice any metal parts in there
  7. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    this is the thumb press? ive tried putting the thumb press at numerous positions and none seemed to trigger the charge
  8. bisco
    52,351
    the wires are inside the handle. the thumb press lever pushes (or releases) a microswitch.
  9. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    All I knew before was that the click the clip made was important.
    Now I'm leaning why the click is important
    Thanks
  10. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    that's the knowledge i'm seeking. there seems to be tribal knowledge on how to charge without the click/clip.. i've seen tesla and chevy charge there without issues. just want to know how to do the same thing
  11. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
  12. vvillovv
    4,324
    1,512
    NY
    edited out Tesla adapter as it's already been mentioned above.
    It's probably not going to be easy to understand exactly what @bisco and @john1701a are talking about until you actually get the clipless handles to work. I'm not getting it yet either, since I've never had the issue.
    Give it time to sink in, sometimes it just takes a while to actually "get it" after reading. ;)
  13. bisco
    52,351
    try to catch someone starting to charge, maybe they can advise
  14. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    caught a tesla owner and looks like they just flip the lever to the up position and it's a go. however still negative in the same position for prime after many tries.
    after coming home, was wondering is it the charge connector lock setting? mine is set to auto and maybe it needs to be at manual? thoughts here? anything to do with that?
  15. John roden
    John roden Member
    67
    29
    West Falls, New York
    I encountered this today on a charge point charger. How do I get it to initiate the handshake?
