Non-Toyoyta oil changes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ggrimaud, Aug 19, 2004.
  1. ggrimaud
    ggrimaud New Member
    36
    Reno, NV
    I have seen a lot of discussion about various problems with Toyota service departments not getting a simple oil change right on a Prius. Has anybody used the Quickie-Lube type service locations to service their Prius? Do they have the correct oil? Filters? Do they get the tire pressure right? Are there any hazards in using these places? They are a hell of a lot cheaper and faster than a dealer. I have used Minit-Lube for my regular car for years and have been very happy. They have my car in their database and always use the same oil and tire setting that are in the database for my specific car. I assume that once I clued them in about the Prius the same would apply.
    Gehri Grimaud
    [email protected]
    In a perfect world we wouldn't need a utopia. - Mike Myers
  2. Dion
    Dion New Member
    128
    Jersey City, NJ
    I have the same question. I'm coming up on my second oil change and I am looking for some place besides the dealer. My dealer is terrible. When I asked the service guy if they use the recommended oil, he said what do you think, we are the dealer. That's not acceptable to me and they don't let you watch the service being performed on your car. I will go to a couple of places and ask if they have the correct oil and filter or if they will do it if I bring my own oil and filter.
  3. ggrimaud
    ggrimaud New Member
    36
    Reno, NV
    I have taken my own oil and filters to the oil change places before. They are happy to use them. In my experience you don't get a discount for the oil and filter they would have used but didn't.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I went ahead and bought two filters and gaskets today at the parts dept. at Tustin Toyota, along with an air filter. I plan on doing my 5k's myself in the future if I can find a place to perform the work.
    Today, I was about due for a 15k service - however, I realized that the dealer's 15k mile service "deal" really doesn't apply well to the Prius. Therefore I only had them perform the 5k, and I bought the air filter at the parts dept. Saved $60.
    The 5k deal includes on top of the $24.95 oil/filter change tire rotation, fluid check/top off, brake inspection, and wiper blade inspection, and runs $54.95 + tax.
    The 15k deal adds "set timing", "safety inspection" and replace the air filter on top of the things they normally do in the 5k service. That service runs $124.95. Now of course, setting timing on an all electronic ignition vehicle is rediculous and near impossible for the std tech. Safety inspection seems like extra padding. The air filter was really then the only additional work performed.
    The sad thing is that in the 5k service, they charge for 5 qts oil though they (should) use less than 4 (it doesn't appear overfilled). They also charge 8 something for the oil filter that's 4.95 in the parts dept, and 1.40 for the crush washer which is 99 cents, or can be bought as a bag of 10 for <$10.. Seems quite padded to me.
    I don't mind dealer service if the pricing is reasonable, but the one size fits all service packages just don't work well for the Prius or other large maintenance interval vehicles. I'll be double-checking pricing on the 30k/60k/90k/100k service to see if that too can be performed myself. Only reason I would go in is for the piece of mind that they may catch something I wouldn't, have tools that I don't, and/or that it's done by someone who does these all day long vs. me once every few months.
  5. jamarimutt
    jamarimutt New Member
    985
    It takes much longer to have the oil changed at the dealer, so I have it changed at a nearby tire/oil place. I can see up close what they are doing, including tightening the drain plug, tightening the oil filter, and adding the correct amount of oil.
    At this place they had the original Toyota filter or a replacement Fram, which I chose. Thay also had several brands of 5-30W oil and I chose Quaker State. Total cost was $19.95.
  6. smtrader
    smtrader Member
    105
    Cerritos, CA
    Rick,
    I want to try changing my own oil on the 04 Prius. The car seems kinda low. Did you have to jack up the car to get to drain the old oil? Any tips? Thanks.
    Brian
  7. greengecko
    greengecko Junior Member
    25
    Syracuse, NY
    Crush washer?
    I just bought oil and a Fram filter to make the first oil change on my 2004 myself. How does one get the correct washer for the oil plug? For some reason this seems too complicated for the guys at the parts store and I haven't taken off the old one to wave in front of people for a match.
  8. smtrader
    smtrader Member
    105
    Cerritos, CA
    I'd suggest the dealer for the washer for your drain plug. Around here, Norwalk Toyota charges $1.14 for a washer...not bad.
    I've been thinking of installing a Fram Quick Change plug. Anyone tried one?
  9. greengecko
    25
    Syracuse, NY
    Yup, a buck-ten. And other than the Fram filter wanting to be turned a FULL turn, my first oil change went smoothly. The existing oil plug wasn't on all that tight, I put it back on a little tighter and that 5w30 does drain quick, even from a cold engine. The low filter mount is VERY convenient. My previous car I had to crawl all the way under and reach all the way up the back of the engine, and I had to blindly clean the gasket seat. With the prius, you don't have to bodily get under it at all, just an arm.
    And yes, it has to be jacked. A cheap hydraulic jack and two jack stands makes for quick, safe work.
    This guy has more instructions:
    http://john1701a.com/prius/documents/Prius...hanging-Oil.pdf which he posted on another thread.
    There has been some discussion about overfill that mystifies me. The shop manual says 3.9 quarts, so I left a swallow sloshing in the bottom of the 1 gal container and after running the engine it was dead on the full mark. I'm sure had I put that little extra in for a round 4, it would have been just fine.
  10. richard schumacher
    7,683
    1,066
    United States
    Do Not assume this. If you overfill it becomes possible for oil to get slurped into the air intake, which will make the engine run crappy and increase emissions. Instead, put in three quarts. This fills the system including filter to almost exactly halfway between the "ADD" and "FULL" marks, which is ideal (and ideally convenient, 'because there's no fiddling with partial quarts). Maybe Toyota should just state flatly in their manuals "put in three quarts".
  11. GT
    GT New Member
    43
    Eden Prairie, MN
    I installed the Fram Quick Change plug at 5K and used it at 10K. Other than draining slow, it seems to work fine. No washer to replace each time.
    I had to pull my Prius up on ramps to fit a gallon jug underneath and collect the oil.
    I changed oil at 3K on all my previous cars. Now I use Mobil 1 and the Fram X2 filter for the 5K interval.
  12. greengecko
    25
    Syracuse, NY
    Do not assume that the $120 shop manual I ordered directly from toyota is correct? Really? I think if it became a warranty issue, I'd rather have followed their instructions.
    Page 17-21 of 2004 Repair Manual, Volume 2 Oil Filter Sub-Assy
    Step 4. Add Engine Oil
    Capacity:
    with oil filter replacement 3.7 liters (3.9 US qts, 3.3 Imp. qts)
    without oil filter replacement 3.4 liters (3.6 US qts, 3.0 Imp. qts)
    dry fill 4.1 liters (4.3 US qts, 3.6 Imp. qts)
    And there isn't an air intake inside the engine, beyond the intake valves at the top of the cylinders. The issue is when it is REALLY overfull the oil will get churned up by the moving parts at the top, froth (i.e., become full of air) which is no longer pumped efficiently or at all by the oil pump and the engine won't get lubed properly.
    Oil is involved in cooling the engine, so underfilling would make the engine run hotter, which does increase your mileage, at the expense of engine wear. Also since each molecule of oil is doing ~30% more work, I'd replace it in 2/3 the time than using the full amount, on the assumption that it will break down faster.
