butterfly value cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by freebird1, Nov 28, 2021.
  1. freebird1
    freebird1 Junior Member
    59
    Dallas, TX
    seen this below from youtube comment but no idea whats involved in doing this
    if any youtube video has below procedure
    prius knocks on cold mornings just pull up the airbox and wipe the underside of the butterfly valve out with a paper towel there is usually oil and water puddles sitting at the bottom the intake under the valve. Its a defect of the third gen.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Not a defect it’s just what the atkisson cycle engine does. It will always have a pool of oil in the bottom of the intake.
    Don’t use paper towels in there they can disintegrate and pieces of towel get in there.
    I always use a ripped up t shirt in strips I soak them in carb cleaner and gently hold the butterfly open and stuff a strip in there and rub away. then remove it and use another strip.
    But this will not fix a knock in the morning. That may be oil related but I assume you have completely cleaned the EGR system at a minimum.
    m.wynn and freebird1 like this.
  3. Mendel Leisk
    41,425
    How many miles?
  4. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Add an oil catch can
    edthefox5 likes this.
  5. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    I keep contemplating putting one on my gen 2
