Key Battery Low
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Go-Green-Pal, Nov 28, 2021.
  1. Go-Green-Pal
    Go-Green-Pal Member
    73
    43
    Greenville, NC
    2018 Prius
    I have a 2018 Prius 3. About 3 days ago, I saw a message saying "Key Battery Low - Replace it". I have a few questions about it.
    1. Is it something easy enough that I can do it myself. If so, what is the battery I should purchase and where will it be available?
    2. How long will the battery last once I get the message? Is it safe to assume that things will work fine at least one more month?
    3. Will I get a dire warning at some point of time saying "change it now or you will be in trouble very soon" or something like that?
    Thanks for your help.
    49,796
    1) yes, the procedure and battery model are in your manual, and amazon, cvs, wherever button batteries are sold
    2) another 3-4 years. there is also a safety start method in your manual if the battery dies completely. but you should test the mechanical key in the door
    3) no, it will just keep reminding you until you change it
    4) all the best!(y)
    #2 bisco, Nov 28, 2021
    Go-Green-Pal likes this.
  3. bisco
    49,796
    this might help:
    watch
    jerrymildred and Go-Green-Pal like this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Mine had that message 6 months ago - so I bought a pack from the SUPERMARKET. They're still in the car, one day I'll change both FOBs. Instructions are in the OWNERS MANUAL - takes 2 mins.
  5. Go-Green-Pal
    Go-Green-Pal Member
    73
    43
    Greenville, NC
    2018 Prius
    That is surprising (especially considering it took slightly less than 4 years to get the battery low message in the first place). Are you sure it lasts that long after the battery low message comes? Perhaps you are telling me the total life of the battery.
  6. Go-Green-Pal
    Go-Green-Pal Member
    73
    43
    Greenville, NC
    2018 Prius
  7. bisco
    49,796
    sorry, senior moment :oops: yes, for a new battery. it cannot be determined how long it will last once you get the message, but it will always start the car.
  8. alanclarkeau
    7,044
    7,584
    Mine gave the message about 5yrs old - but I've only used it for about ½ that time - I had the battery out of the 2nd FOB for 2½ yrs, then swapped FOBs - taking the battery out.
    It would be a combination of battery age and battery use which causes it to degrade. New batteries were cheap.
  9. jerrymildred
    jerrymildred Senior Member
    11,518
    14,127
    Tampa, FL
    What a slowpoke! :LOL::LOL:
    Last time I changed one of those I timed it. It took all of 14 seconds. :whistle: (Not counting the extreme effort involved in getting the battery out of the ridiculous packaging.)
    CR94, Tande, fuzzy1 and 1 other person like this.
  10. alanclarkeau
    7,044
    7,584
    OK - I said 2 mins - but that was sort of a guess. I didn't time myself. But I think it was slightly more than 14 seconds - I'm old and slower. Probably sipping coffee while doing it too.
    jerrymildred likes this.
  11. Mendel Leisk
    38,952
    How are the fourth gen fobs?
    My impression changing the battery on our 3rd gen: the innards are surprisingly exposed and fragile looking, once you've popped the case open. I'd much prefer if there was a little cover, just for the battery, and the circuit board and the rest of it stayed covered.
  12. CooCooCaChoo
    CooCooCaChoo Senior Member
    911
    509
    Cow-lee-fornia
    2023 Prius
    Pretty much the same. Circuit board inside clam shell.
    jerrymildred and Mendel Leisk like this.
  13. jerrymildred
    11,518
    14,127
    Tampa, FL
    My 14-second time was for a 4th gen. You do have to be careful that it doesn't spew its internals all over the table. There's a 25 second penalty if that happens. :D
    This time I videoed the process. I didn't really rush this time. Still under a half minute.
    Go-Green-Pal, alanclarkeau and fuzzy1 like this.
  14. fuzzy1
    10,271
    ... and you probably counted the time needed to get the new battery out of its @$E#%! packaging.
    jerrymildred and alanclarkeau like this.
  15. jerrymildred
    11,518
    14,127
    Tampa, FL
    What is it with those battery packages?? Talk about child-proof over-kill.
  16. MIkeDr
    MIkeDr Active Member
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    Wasn’t there an issue with kids swallowing these batteries thinking they were candy or something?
    krmcg likes this.
  17. jerrymildred
    11,518
    14,127
    Tampa, FL
    I'm sure that it's to keep kids from swallowing them, but I don't know of any other object that size that's that hard to get out of the package.
  18. alanclarkeau
    7,044
    7,584
    Mine looks easy - but isn't!!! The battery <POPS> out - but then needs a pair of scissors to get to it.
    ANYONE know where the scissors are?????????
  19. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
    Taste one, heard they even added a bad taste to them to try to get kids to not put them in their mouth. LOL
  20. Go-Green-Pal
    Go-Green-Pal Member
    73
    43
    Greenville, NC
    2018 Prius
    I was being lazy and just switched to my spare key fob instead of actually changing the battery. Since my previous key fob lasted over 3.5 years, I thought I probably won't have issues for another 3.5 years. To my surprise, this spare one lasted only one month or so and then again, I started getting the same "low battery in key fob" message.
    Finally, I moved my lazy nice person and went to store bought new battery and changed in both the fobs. As all of you said it is very easy and did not take much time.
    So, anyway this means it looks like the battery will be decaying even if you are not using the fob (maybe I should not have replaced the battery in second fob, since I am not using it - it will unnecessarily decay now).
