BumbleBee Batteries, the Unspoken Company.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jzchen, Dec 1, 2021.
  1. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    Just thought I'd bump this website as MAYBE they have batteries in stock?
    https://bumblebeebatteries.com/
    Who knows, hopefully we don't drive away anyone with experience with them...
    REVVL V+ 5G ?
  2. PriusCamper
    PriusCamper Senior Member
    11,191
    4,560
    Pacific Northwest, USA
    They used to be dominant in Honda Hybrids... Their cylindrical replacement cells were once the preferred replacements packs for those who live near Oregon. This is the first time I've noticed their Prius offerings. Does anyone know what kind of module they use in their "High Capacity" Prius packs with 5 year warranty?
    My main gripe about them is the way they welded their cylindrical cells together causes them to explode when discharging during reconditioning. Not sure if they updated their design yet or not?
    jzchen likes this.
  3. Rmay635703
    Rmay635703 Senior Member
    2,599
    1,616
    Somewhere in Wisconsin
    2013 Chevy Volt
    They still are the go to for Honda, out of the aftermarket options they are likely near the top
    but unlike Honda you can buy new OEM Toyota replacement batteries.
    The guy(s) that used to hock those cells here got mad and left priuschat if memory serves, would have to see if that Scott the battery guy remembers what happened
    jzchen likes this.
  4. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    They do say something about welding the battery ends to the frame. I was searching for it right now but did not find it anymore, (at least for now). They also mentioned something about only allowing approved cell balancing chargers to keep your warranty.
    It is interesting the focus on the battery junction/connection. I read somewhere that Tesla upgrades the battery terminals to Inconel for Ludicrous Speed. Increasing current/Decreasing resistance is important with respect to heat build up.
    We do not get 6000 mi/yr which is one requirement for their warranty. It always bugged me that I would essentially void it the first year of use because of this....
    REVVL V+ 5G ?
  5. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    Found it:
    "The positive and negative collectors have been redesigned to allow for approximately 50% more weld points between the plates and the collectors. The negative collector is welded to the battery case, rather than just pressure contact. These improvements allow the highest capacity and lowest internal resistance of any hybrid battery cell on the market!"
    REVVL V+ 5G ?
  6. Tombukt2
    9,597
    1,682
    Ali baba has some cylinder type cells on its site sposedly fit Prius most models
    SM-A715F ?
  7. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    You reminded me of this company. I could barely remember the name! (I should bookmark it)...
    Get Toyota Prius Hybrid Battery Replacement | EnnoCar
    REVVL V+ 5G ?
  8. Hagleboz
    Hagleboz Junior Member
    Murrieta, CA
    They were very slow to ship when I bought my new replacement battery from them. Now it's failing after only 18 months. One of the most disappointing products I've ever purchased.
