2007 Prius Red warning light and check engine lights on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by szn20011, Aug 26, 2021.
  1. szn20011
    szn20011 New Member
    atlanta
    hello,
    I have 2007 Prius and the red warning light and check engine lights has appeared also the rear ac fan has started to blow air. I have taken out the HYBRID battery and tested each and every cell the battery is all good but the lights are still on. any help?
    52,390
    you need to read the trouble codes. is it hot there? is the battery cooling fan and intake grille clean?
    the modules have to be tested under load
    SFO likes this.
  3. szn20011
    szn20011 New Member
    atlanta
    The codes are reading C1241,C1259,C1300,C1310,P0A80,P3018.
    Also yes the cooling fan and intake grill is clean.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,088
    1,997
    NJ-USA
    Specifically you need to be able to read codes and data from the HV battery ecu. A good option is to get a mini VCI cable (with a bootleg copy of Techsyream - Toyota's diagnostic software) and install it on an old windows laptop. Another option is to get the DrPrius (or Hybrid Assistant app - android only) with a compatible OBD2 bluetooth adapter.
    Then you will be able to see what codes are triggering the warning lights. Also can monitor battery block voltages while the car is driving- during discharge and charge loads. Much more useful than looking at static voltages while it's just sitting there.
    szn20011 likes this.
  5. ChapmanF
    18,545
    Just one notch less specifically, I would start by reading whatever codes are reported by any ECU in the car. Techstream has a "health check" button that makes this easy.
    There may be codes in the battery ECU (probably are, given the fan behavior), but anyway the health check will find out. The ECU making the call to light the warning light is the HV ECU, so it will have one or more codes also (which might only be P3000, meaning to go look at the codes from the battery ECU). With the health check you won't miss any.
    szn20011 and JohnPrius3005 like this.
  6. bisco
    52,390
    what are you reading the codes with?
  7. szn20011
    szn20011 New Member
    atlanta
    Hi So I bought the obd2 scanner and this is what the voltages for each cell are. there are two that are just a tad bit lower than the others. could be the cause of the problem?
    #7 szn20011, Dec 3, 2021
  8. mr_guy_mann
    4,088
    1,997
    NJ-USA
    So, the HV battery ecu monitors the voltage of 14 blocks. Each block is made up of 2 modules. (So 28 modules total- all connected in series). Each 7.2V module is a sealed assembly made up of six 1.2V Ni-mh cells. (So 28 x 7.2V = 201.6V - nominal, the actual voltage goes higher).
    You have two blocks that each read about 1.5V lower than the rest. That is almost certainly indication of two bad modules.
    You can search the forums here to review repairs options. New (Toyota or newpriusbatteries.com) -most $$$ and reliability- should last 10+years. Rebuilt/ "used" (greenbean, dormann, the guy across town)- slightly less $$, might get a couple years- be sure to know the warranty.
    DIY -buy a complete pack from a wrecker (possibly best $$ to reliability to time ratio). Or get a few modules and just swap them ( and swap again, and again, aka "whack a mole"- least cost and reliability). Get some modules and hobby chargers to cycle all the modules individually(needs the most time and knowledge to achieve a good result). Last is to get some modules and a grid charger to cycle all the modules at one time (less time needed than hobby chargers but costs more for equipment)
    Again, might get a couple years, depends on luck and how much you put into everything.
