Car won’t start without jump start
Discussion in 'Prime Technical Discussion' started by puupy30, Dec 3, 2021.
  1. puupy30
    puupy30 New Member
    Arlington, VA
    2017 Prius Prime Plus wouldn’t start the other day. Gave me a message “Low 12-volt battery”. So, I put in a new 12 volt battery. But once new battery was in, car was totally dead. But I jump started it connected to my friend’s car with jumper cables. And I can drive no problem. Problem is that after I turn it off, car needs a jump again to start. Any ideas???
  2. Salamander_King
    Salamander_King Senior Member
    10,963
    8,839
    New England
    Did you check the cable connection to the new 12v battery? Also, more importantly, was your 12v battery fully charged when you installed it? Where did you buy it and who installed it? Sound like you have a dead new 12v battery that could be a defective one. Another possibility is the master fuse is blown? But, if jumping from the battery post starts the car, there must be at least continuity from the post to the car. I would check the new battery first.
    If you have a battery tester, that would give you the health of the battery as well as SoC. If you don't have a battery tester, but a simple multimeter, then at least check the resting voltage of the new 12v battery. If it is not reading above 12v, then most likely you got a defective battery.
  3. schja01
    schja01 One of very few in Chicagoland
    1,732
    1,156
    Chicagoland
    2018 Prius
    How about if the wiring to the 12V is somehow defective and prevents charging and otherwise not powering the vehicle. Once the car is jump started the DC-DC converter powers the vehicle until it gets shut off and the cycle repeats. Just spit-balling.
  4. pghyndman
    pghyndman Active Member
    498
    464
    CT shoreline
    At the risk of sounding condescending (no offense intended) are the battery terminals uncovered on the new battery? Batteries often are shipped with thin plastic caps on one or both terminals and (especially black or clear ones) can easily be missed during installation which prevents a 12v connection:
    #4 pghyndman, Dec 3, 2021
    dig4dirt likes this.
  5. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    DAYYUM! you never know!
    Actually hope that is it, makes sense!
    Or just a defective 12v
  6. Mendel Leisk
    38,214
    I don't think the clamps would go on, with the plastic caps still in place.
    schja01 and fuzzy1 like this.
  7. vvillovv
    vvillovv Senior Member
    3,529
    1,242
    NY
    I'd flip through the owners manual for hints about what to try next. Some suggestion to start ya with are
    Section 8 * When trouble arises
    688 If the hybrid system will not start
    see pg 689 sub heading Emergency start function
    694 If the 12-volt battery is discharged
    Section 9 * Vehicle specifications
    743 Items to initialize
