rusty brake drums
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Iggy2018, Dec 8, 2021.
  1. Iggy2018
    Iggy2018 New Member
    Maine
    2018 Prius c
    The brake drums on my 2018 Prius C seem more rusted than one would expect after less than two years and 15,000 miles -- even in the snowy/salty Northeast. I had a 2008 Prius for ten years (also in New England) that I don't remember having rusted so soon. Also, I've seen posts in this forum from other owners (also in snowy places) who say their Prius with more years and miles than mine haven't had a lot of rust.
    The service director at Toyota told me that the rust is normal and not a problem and that there is nothing to be done about it now, or to prevent future rust. That seems plausible, but I would appreciate anyone weighing in on whether this seems normal/expected; if it's dangerous, and; if there is anything that could/should be done about it.
    The attached photos are from 03/31/21 (1st photo) and 12/02/21. I purchased the car new in August 2018. It is parked uncovered in a driveway. After storms, snow is removed from the driveway within hours. It has been driven minimally in snow, however, there is, of course, salty mush on the roads for days after it snows. I wash it after there's been a lot of snow/salt but not very regularly otherwise (it's dark gray and doesn't need it often).
    Thanks!
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Absolutely normal.
    Not to worry.
    NOW.....if you REALLY like to worry about things like this, the next time you are in a service shop, ask them to let you see
    the entire underside of your car. You might have a stroke at the sight of all that rust.
    Mendel Leisk and Iggy2018 like this.
  3. bisco
    51,846
    toyota doesn't waste any energy on places rust won't cause a serious problem, but sometimes brakes are a trouble spot. it's usually discs though
    Iggy2018 likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Huh - Brake Drums - they're all DISKS.
  5. ChapmanF
    18,080
    Those photos look less disc-like than I might expect.
    Mendel Leisk and alanclarkeau like this.
  6. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    Rust on the outside of the drums is normal. rust on the inside of the drum, especially the drum lining where the shoe makes contact is the important part of the drum you want to keep rust free.
    If only worried about appearance, you can always paint the outside of the drums, like many paint their disk brake calipers for appearance. Just don't get paint on the linings, shoes and other working parts around the hubs..
  7. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    OP has Prius C, so discs in front, drums in rear. (just saying, posted in wrong subforum)
    Nothing to worry about from the photos.
  8. Iggy2018
    Iggy2018 New Member
    Maine
    2018 Prius c
    Thanks a lot for your response. I spent some more time with Google and think that maybe my previous cars had disc brakes and/or more occlusive hubcaps, because I don't remember ever noticing what, I have now learned, is very common.
    #8 Iggy2018, Dec 9, 2021
    vvillovv likes this.
  9. Mendel Leisk
    41,334
    Just figured it out: OP's mis-posted, has a Prius c.
    For the rusty drums, maybe a super-thin application of anti-seize compound? I use that on hub faces, every time the wheels are off.
    dig4dirt likes this.
  10. Mendel Leisk
    41,334
    Your location (Maine) gets abundant road salt I’d think. If rust bugs you, consider raising the car for a look see. I’ve had good results with boiled linseed oil, just brushed on. Even over existing rust, stops it dead.
  11. alanclarkeau
    7,045
    7,592
    It's been moved to "c" now - thanks to the Moderator!!!
