Decrease in MPG
Discussion in 'Prime Fuel Economy & EV Range' started by Hoan, Dec 9, 2021.
  1. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
    Hi everyone,
    My 2020 Prime XLE is getting around 45 MPG. 30k miles so far, new tire good tire pressure, oil change every 5000 miles. I'm not using AC or heat. Yet my milage is around 45 MPG. Does anyone have idea why my MPG dropped?
  2. schja01
    schja01 Senior Member
    1,827
    1,217
    Chicagoland
    2024 Prius
    Limited AWD-e
    Winter fuel blend?
  3. bisco
    51,539
    new tires, are they LRR?
    what has your previous mopg been like? how are you measuring it?
  4. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
    No, it stated this last summer. I drive like a granny too.
  5. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Have you checked air filter?
    Do you have any pets that ride in car? There is also HV Battery filters that should be checked too.
    Brakes or eBrake checked out?
  6. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
    The new tires are low rolling resitence.
  7. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
    I take care of my car well. New engine air filter, new cabin air fliter. I clean my traction battery air filter once a month. No pets in the car, I use Seafoam every oil change to clean the fuel injectors. And to ounces to clean the engine before my oil change as well. Even cleaned my intake mainifold, EGR, and throttle body at 25k miles. Before on the dash I was getting 55ish to 62 MPG on hybrid mode. Also my total range went from 525 miles on a full tank to 420 miles range on a full tank when I fill up.
  8. bisco
    51,539
    definitely winter blend and new tires then. might be worth checking for brake drag
  9. Salamander_King
    Salamander_King Senior Member
    11,010
    8,940
    New England
    Does it get cold in LA? My HV-only mpg for the same route dropped from 65mpg ~1month ago to ~50mpg just a few days ago when the temp dropped to teens F. I was getting ~35 miles of EV range from a full charge, but now, I am lucky if I can get 20 miles in my morning commute.
  10. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
    It's not that cold here in Los Angeles. I also clean the MAF sensor with each oil change as well.
  11. bisco
    51,539
    that's a lot of unnecessary maintenance. perhaps you've overdone something
    MTN likes this.
  12. BiomedO1
    3,156
    1,669
    SacTown, Ca
    I guess you haven't heard the old adage; "If it ain't broke, don't mess with it". How did you clean the MAF sensor?
    You really shouldn't be exposing practically new sensors to those harsh chemical strippers. Those cleaning products you mentioned are designed to strip away carbon, varnish, and oil. Using 0w20 or 0w16 full synthetic oil with advanced detergents - accumulated buildup is minimal at best; especially if you've been keeping up with the OEM maintenance requirements. Your more likely to damage or shorten the life of those sensors. That's just my 2-cents; take it or leave it.
    Your mileage drop is more than likely weather and winter gas blend related; unless you threw off one of your sensors. The sensor may still be within range, otherwise it'll throw a code. Check all four wheels, you may have mechanical drag due to a frozen caliper slider pin.
    #12 BiomedO1, Dec 9, 2021
    MTN and Salamander_King like this.
  13. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    I thought winter blend gave you more mpg?
    iPhone ? Pro
  14. bisco
    51,539
    nope
    MTN likes this.
  15. bisco
    51,539
