Driving only in power mode
Discussion in 'Prime Fuel Economy & EV Range' started by Oskar, Dec 12, 2021.
  1. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    I was wondering if anyone here has tried to drive in POWER mode only for an entire tank of gas. I'm curious what the mpg would be for the Prime. Am planning to try it myself at some point, but wondering if anyone here has done it.
  2. Ovation
    Ovation Active Member
    156
    130
    Quebec
    I do it (several months at 1000 miles/week) because I have a lingering ankle injury and power mode is the most comfortable setting. Prior to that I almost always used eco mode. Only noticed a very marginal difference when weather was comparable.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    I have never done it, but in theory, there should not be much difference in mpg either in Power mode or Eco mode. The only difference is the throttle response, so you can drive Power mode economically or Eco mode wastefully either way. That being said, in addition to the throttle response, Eco mode does restrict the use of HVAC, so overall you may see a slight decrease in mpg if you are not using Eco mode.
    fotomoto likes this.
  4. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    Well, I'm going to give it a shot at some point. Will report back here on my results.
  5. bisco
    52,388
    if you're heavy footed and pay no attention to driving for mpgs, eco mode may save a few sheckles
  6. 0ddj0b
    0ddj0b New Member
    van
    2022 Prius Prime
    I have found that unlike the other 2 modes (normal and eco), the ICE never stops once you shift into it, even if you shift back into ECO or NORMAL mode (until the car is turned off). So that's a bit of a downer, since you can't casually shift into it and the back into EV only mode on a drive, again unless you completely power the car off.
  7. Salamander_King
    11,024
    8,970
    New England
    Not that I have tried using POWER mode extensively, but from my few times of using POWER mode, that is not the way my PP behaved. I could certainly switch back and force between POWER, NORMAL, and ECO modes and still stay in EV mode without ever having the engine come on, that is of course I have enough EV range left in the battery.
    Hicksite and Ovation like this.
  8. bisco
    52,388
    confusing eco/normal/power with ev/hv?
    plus,the engine has to shut off, or you should see a dealer
  9. 0ddj0b
    0ddj0b New Member
    van
    2022 Prius Prime
    My apologies, I was able to go back into full EV after shifting into power mode today.
  10. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    May have been warm up cycle?
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    The only way I drive it. 50+ mpg highway (65-80mph legal speeds here). In town, I’m EV only + PWR mode only and see 28-29 miles estimates upon start up. 2019 42k miles.
