Featured where is back-up beep location on the 2021 prius prime?
Discussion in 'Prime Technical Discussion' started by dino woo, Dec 13, 2021.
  1. dino woo
    dino woo New Member
    el paso
    where is backup beep location on the 2021 Prius prime?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    The one inside - if it's the same as 2016, I think it's under that dash - and is used for lots of beep warnings. Don't try cutting it out - I suspect the computer would get upset.
    Get your dealer to TURN IT OFF - it'll just give one beep to confirm that you've selected REVERSE. No idea why dealers don't do it automatically.
  3. Salamander_King
    Salamander_King Senior Member
    11,004
    8,925
    New England
    MTN likes this.
  4. CharlesH
    2,792
    1,156
    Roseville, CA
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    739
    Monument, Colorado USA
    If you mean that awful "UFO" speaker, it's on the engine side of the radiator, to the right of center, before you see the right headlight. But you can't see it unless you remove the clips on the plastic cover. (I think there's 6) If you are careful with a small screwdriver they pop off and are reusable. Some of us have taken out the UFO speaker (officially called a pedestrian speaker, part of the vehicle proximity notification system) and wrapped sound-deadening material around it to quiet it. I believe they've disabled any software options for turning it down...mine was WAY to dang loud, especially in reverse. (It also comes on when driving slowly but not as loud.)
  6. Ovation
    Ovation Active Member
    156
    130
    Quebec
    That is correct. 2021 models and newer cannot adjust the volume level via software.
