2012 repair help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Joseph prius, Dec 22, 2021.
  1. Joseph prius
    Joseph prius New Member
    Oc ca
    I am helping a friend with his repair.
    He recently bought a car with 180k
    Jtdkn3duxc1487151
    His coolant diverter y coupling got a hole and he overheated, he summerized a blown head gasket. He used blue devil to patch the leak (put blue devil in overflow resivour and removed the thermastat from the engine (just found out this part today)) the engine has been turned over a few times by jumping it but dies immediatly before idle. So it hasnt been ran. He replaced the plugs and air filter.
    This this when i joined in. He jumped it for me and i saw what it was doing. I read that it could be fuel pump relay or mas air flow sensor or coil pack. We unplugged the mass airflow and tried a jump while maf was disconnected.
    It turns over then dies when jumped.
    His battery was old and dead also, maybe from trying to start it too many times (battery age is unknown) He replaced the battery connected the maf and read the codes. P0113 p0102. Was this because earlier we unpluged the sensor and tried to start it?
    Later he removed the air filter box to visually inspect the outside of the intake manifold. His roomate sugested this because he suspected a vaccum leak. (No obvious visual damage)
    New codes, p0121 p0123 p2135.
    Replaced the y coupler. Remounted the air filter and assembly. And with the new battery, attempted to start, nothing.
    Battery showed low voltage on center display. Jumped it from under the hood. The engine tried to turn over then dies like before.
    Im trying to help over the phone with fb messenger.
    I know the HG is a problem because the aluminum block. But i dont know if its really blown or if things are really screwed from the over heat. I only know this was his assesment because it died after overheating. Now the blue devil is setting in the reservoir.
    Do we need to rest the codes now that things are reconnected in the engine for it to work right?
    Why would his display show the battery low if it was just swapped?
    Now we have a code reader i feel like we might be able to track down repairs but the battery showing low is concerning.
    I was trying to figure out the trouble shooting step before we had the reader but now we do, so id like to proceed in an order that makes sense. I dont know much about cars but have done a fair bit to my 94 ranger. (Iac valve, erg, plugs, altenator, starter etc.) But i have come to his vehilce in a far worse state than my experience is fimiliar.
    Any help would be appreciated
  2. JC91006
    JC91006 Senior Member
    16,761
    8,562
    Is there a little history on this car? How did it come to being dead? Bought it that way?
    The battery state of charge meter, the middle screen you looked at, that meter shows the HV battery status, not the 12v battery status. If you have drained the HV battery to the point it can't start the car, it would need to be charged/replaced before you proceed. The engine starts by using the HV battery.
    Has any of you guys owned a Prius before? It's a little different than fixing a regular car.
  3. Joseph prius
    Oc ca
    I am new to prius and understand there is a bit of difference. But i dont know / understand the differences.
    The history is unknown to me but...
    The car was running till it sprung a leak, it died when it overheated.
    I will look into charging the HV to see if it can be done before replacement it needed. Any help on charging or testing it for need of replacement would be helpful.
    It is very helpful to know it starts off that battery. Out of quriosity, what functions does the smaller battery preform?
  4. JC91006
    16,761
    8,562
    The small battery starts the computers in the car, headlights without turning on the car, radio etc. The actual starting of the car, it requires the HV battery.
    If sometimes you hear the engine turning for about 10 seconds and dies, the engine actually never started. It's just the HV battery spinning the engine for the 10 seconds.
    If the car sprung a leak and overheated, do you know for sure if this is the case or just what was described to you? The car would have stored many failure codes, best to retrieve those so it can definitively point you to the failure (as oppose to someone telling you what the failure is)
  5. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    If the high-voltage battery will crank the engine then you can do a compression check to see if you damaged The engine by overheating it. But it really sounds like you need a grid charger to bring the high-voltage battery back.
  6. Joseph prius
    Oc ca
    I was told it happened to the current owner. I saw the hole in the hose fitting. Overheating...was explained by owner.
    As far as codes go... i will read about the codes listed.
    P0102
    P0113
    P0121
    P0123
    P2135
    But since we unpluged the maf and tried starting it i wonder if the first two were false. Would the code still show after its reassembled if the maf is good. Meaning is it stored or does the comupter only give you current problems and clears itself of things we repair as we resolve them?
  7. Joseph prius
    Oc ca
    The Hv will try to crank for a short time. At other times it wont. When the old 12v was on we chargered it and got a better crank, thats why i misunderstood what its job was. But that confuses me some too, because of its effect to get another crank from the HV. Unless the hv get a little juice from resting. I will search out grid charging next.
    Any idea what the compression should be for each cylinder?
  8. bisco
    51,840
    tech stream is the gold standard prius reader,and gives sub codes. dr prius phone app is pretty good.
    you can get anything you need at techinfo.toyota.com
  9. Joseph prius
    Oc ca
    P0102
    P0113
    P0121
    P0123
    P2135
    The list goes on.
    P0000 x4times
    P0351
  10. Joseph prius
    Oc ca
    Can i hook the hv up like this...
    And use this to charge it?
    Tenergy T180
    #10 Joseph prius, Dec 23, 2021
  11. 2010moneypit?
    314
    122
    Beaumont ca
    Be careful hooking up the grid-charger. Even at a low state of charge the hybrid battery may be able to still kill you.
    So yes after the battery sets for a while it will get a surface charge and it may crank for a short time but if you keep running the battery down you will damage the high voltage battery.
    As far as compression goes I believe 150 would be a good starting point be within 10%. Engines may have higher compression. Maybe somebody else can chime in on that. I do recall reading somewhere 180 per cylinder a quick Google search
