  1. w84me
    w84me Active Member
    144
    224
    Sacramento
    Swapped out the stock steering wheel with the eBay leather/piano black wheel. Feels so much better and added 7 rwhp
  2. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Swapped over to the snow-tire-equipped wheels. Checked all brake pads and rotors and lubed all caliper pins with Syl-Glide.
    xliderider likes this.
  3. camperprius
    camperprius Junior Member
    SoCal
    What are the specs on your wheels? That’s the exact fitment I’m looking for. What width and offset are they? Very clean setup!!
  4. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    18x8.5 38 offset
  5. nrg
    nrg Junior Member
    california
    Thank you sir!
    Just ordered a bottle from grainger. Will be doing my egr pipes and cooler next week. I needed a way to clean well and fast and this is the solution.
  6. ASRDogman
    ASRDogman Senior Member
    7,792
    3,976
    Pressure washer and oven cleaner.
  7. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Have not posted in this ghost town in forever.
    I guess pretty much changed up Everything too long to list.
  8. AzusaPrius
    AzusaPrius Senior Member
    2,225
    930
    Installed some JDM headlights today, removing the bumper is not hard at all, should take 30-45 minutes to do.
    The sidemarker in Japan is white but has no light.
    The U.S version is amber and has a light.
    There is a stamp of the exact bulb insert so I mocked it open.
    Unfortunately the sidemarker is only a reflector and no light can pass through it.
    So I installed them as is without the sidemarker light bulb. 20220108_144932.jpeg
    http://www.RedBullet.net
    https://ProjectLithium.com/?ref=mG0GE
    http://www.Pulstar.com
    http://www.PlugOutPower.com
    Use code 7373
    http://www.hybridpit.com
    Use code azusa
    http://CatStrap.net
    Use code azusa
  9. ChapmanF
    18,501
    What side of the road do they drive on there?
    I came very close once to buying some LED headlight assemblies someone was selling here, until I realized at the last minute they were from an RHD country and would have the low-beam cutoffs shaped wrong for the US.
  10. 2002mgraves
    2002mgraves Junior Member
    Mind me asking which visors these are? Or someone point me in the right direction...
    There's so many options, these are nice. TIA
    Fitcious likes this.
  11. drbtz
    drbtz Member
    102
    51
    United States
    I don't hang around PC much anymore. Haven't done anything recently because it's snowing here. I will be doing some light body work this spring including removing 3 small dents in the read driver side quarter panel. I'll also be repairing my crack bumper, basically restoring the car to "like new" look.
    Possibly adding warm air intake for winter.
    #18971 drbtz, Jan 15, 2022
  12. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I ordered new headlights for my 2015. Started yellowing at the top. I ordered ones that are black instead of the stock chrome ones. My tail lights are also black, so it will look better all around.
    m3pare and Burna J like this.
  13. Montgomery
    2,254
    2,241
    Orange County, CA
    Here is the finished product! Took about 1 hour. Hardest part is replacing all the darn clips!!
  14. ASRDogman
    7,792
    3,976
    They kinda of blend right into the body color. Nifty!
  15. Fitcious
    Fitcious Member
    195
    88
    Los Angeles
    Here you go! I got these at $55 last year. Prices have increased but these are the most flush looking ones. All the other ones I’ve seen are either too big or looks like a hood which I dislike.
    Auto Ventshade AVS 894047 Low Profile Dark Smoke Ventvisor Side Window Deflector, 4-Piece Set for 2010-2015 Toyota Prius
    2002mgraves likes this.
  16. Matth Torrijos
    Matth Torrijos Active Member
    114
    208
    Poway
    Bought some dodge challenger side skirt splitter and fabricate it to fit my Gen 3 hope it doesn't look too bad
  17. Montgomery
    2,254
    2,241
    Orange County, CA
    That really looks sharp!
    Matth Torrijos likes this.
  18. icyrius
    icyrius Active Member
    242
    115
    Florida, USA
    2014 Prius v wagon
    Would you mind sharing where you got them?
  19. Montgomery
    2,254
    2,241
    Orange County, CA
  20. MPGRaja
    469
    1,680
    Corona
    I’m trying to download Techstream but having a hard time getting it to work. The OBD/USB doesn’t get recognized. Anyone local (SOCAL) can help?
