2013 Prius v VSC, ABS, CEL lights all on!!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Ravi kukreja, Dec 25, 2021.
  1. Ravi kukreja
    Ravi kukreja New Member
    Pakistan
    2013 Prius Alpha
  2. Ravi kukreja
    Pakistan
    2013 Prius Alpha
    Prius v 2013, suddenly four alarm light pop up after 15km driven.
    ABS, Break,VCS, Check Engine.
    12v Battery already replaced to new one.
    Gas Cap checked.
    Still warning lights Pop up.
    Anything else can be done?
  3. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Could be an intermittent/open connection to one or more wheel sensors. Been there.
  4. ChapmanF
    15,648
    It might take a week, but eventually someone will probably suggest finding out why the lights are on.
    If you do not have a scan tool for retrieving the trouble codes, you can get at least the ABS and VSC codes using a simple length of wire, and counting light blinks.
    JohnPrius3005 likes this.
  5. Air_Boss
    3,952
    1,083
    New Yawk
    In my example, intermittent wheel speed sensor signal was the code, FWIW.
  6. ChapmanF
    15,648
    ... which kind of reinforces the point that if a different person has lights come on in a different car, finding out what the code is in that car might also help that person find that problem.
  7. Air_Boss
    3,952
    1,083
    New Yawk
    Point taken though there are experience and typical fault paths to consider, as well.
  8. bisco
    49,500
    do you have a trustworth mechanic with a prius scanner available?
