Hood Strut Kits for Gen 4 Prius??
Discussion in 'Gen 4 Prius Accessories and Modifications' started by ColoradoBoo, Dec 26, 2021.
  1. ColoradoBoo
    ColoradoBoo Senior Member
    1,259
    864
    Monument, Colorado USA
    One great mod I did on my 2005 Tacoma was removing the stupid 1950's-ish hood bar and installing struts. My Tundra came with them.
    I've been researching if a strut kit exists for our Gen 4 Prius but not having much luck...even on EBay (which I only search when in desperation).
    Maybe because our design leaves no room along the edges for placing a connection?
    Or maybe I'm missing something? Anybody have them and want to help a brother out? :)
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I was in the opposite camp, I wanted to go retro and take the simple approach. I tried looking for a hood support rod for my 2010 Toyota Camry when the gas support struts went bad long ago but was unable to find anything. An appropriately sized length of wood served its purpose to prop the hood open for many years, until I finally installed replacement gas charged struts when my son started driving the car as a daily driver.
  3. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    ColoradoBoo likes this.
  4. ColoradoBoo
    1,259
    864
    Thanks, JTERAN5! I didn't have that website in my list...they are now!
    After looking at their picture, it seems our Prius have pre-drilled mounting holes where those go...great idea!
  5. ColoradoBoo
    1,259
    864
    A FYI for folks....even though it seems our Prius is pre-drilled with mounts for the struts, Toyota parts said they do NOT have Toyota OEM Struts or mounts lists for installing them. Must've been a miscommunication between the design engineers and the production team.
    Anyway, I got my black pair ordered from Hybrid Pit.
  6. ColoradoBoo
    1,259
    864
    After a lengthy shipping delay off the coast of California (made in Japan), my strut kit came in from Hybrid Pit.
    But the lower brackets are positioned wrong and don't connect with the struts. They are looking for the right ones. If they can't find any, I'm thinking of re-engineering the ones I got to make them face the correct way for use. (They have tabs that go down and are in the wrong place...so would have to remove them, probably just pound the flat, and find a way to secure the bracket so it didn't move when the struts do their thing.
  7. ColoradoBoo
    1,259
    864
    Update: Was not able to get those lower brackets repositioned to get them to work. Hybrid Pit also had their folks trying to figure out something but was not.
    Returning them to them for a full refund. They were nice enough to pay for return shipping...so kudos for that!
  8. Mendel Leisk
    41,792
    The OEM hood support rod is so simple and bullet-proof.
    I know, once you get an itch, but...
    jerrymildred likes this.
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    I agree.
  10. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    Mine are still in the packaging. Haven't bothered to try them yet lol.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Yup. The air struts tend to vary a lot in their willingness to assist and support depending on the temperature and then they finally just give out. I've had a few of them do that. But the simple hood prop? Somehow, it doesn't seem to care how old or cold it is.
    ColoradoBoo and xliderider like this.
